Balancing the Rotating Assembly, Parts needed?
What Parts are needed To Balance the Rotating Assembly?
Rebuilding my B18C1
*I have a Type R Crankshaft, Eagle Rods and CP Pistons available.
Swapped in a B20 to daily drive my car, following parts are not available
*Crank Pully, Flywheel, Clutch and Pressure Plate are on my B20
What Parts do I need to buy To Balance the Rotating Assembly?
I Have found videos and pics showing Machine Shops use a Harmonic Balancer and Flywheel, but it looks like In House Harmonic Balancer and Flywheel with counter weights.
Rebuilding my B18C1
Honda's are internally balanced, that means it's not balanced with flywheel or crank pulley. Externally balanced is balanced with all the external parts, flywheel and pulley.
https://help.summitracing.com/app/an...ine-balance%3F
