Rear Motor Mount Insert
This is what yack said a while back....I tried it another way before he said this(didn't succeed) and didn't touch it again until I pulled the tranny, I like the mounts
1) jack front of car up
2) remove lower subframe brace (4 bolts)
3) remove all rear tranny mount bolts
4) gently, pull heater control valve up about 2-3 inches towards hood/firewall
5) push rear tranny mount up till it hits HCV (it will still be straddling the rear subframe motor at the very top, but room to fit the mount is there)
6) reverse steps and proceed to kill any and all V8's
It's that easy, no need to remove the strut bar, tranny, header, O2 sensor, half shafts.......etc.....
20 mins and some bloody knuckles.
the most easiest way:
take off all the bolt on rear tranny bracket, then all the bolt on the rear mount, then the stuffs should be able to come out.
How about switching out the ECU and Cams while you're at it?
austin thanks for the step by step
but do you have pics of this? > 4) gently, pull heater control valve up about 2-3 inches towards hood/firewall
what does the HCV look like?
arno, i'll call you if i'm totally stuck. haha thanks all
chrisff521
May 19, 2010 06:06 AM
travis
Aug 28, 2004 03:42 PM
SurferX
Mar 3, 2003 02:16 PM
. TIA guys
