Using Bosch LSU 4.9 wideband sensor, directly connected to ecu.
Old May 24, 2020 | 01:05 PM
Emiel1988's Avatar
Default Using Bosch LSU 4.9 wideband sensor, directly connected to ecu.
Hey Guys,
After a few hours research i cant get clear if i can connect a lsu 4.9 wideband sensor direct to the ecu without the use of a controller.
I have read the article from Ha motorsports and i want to install a lsu 4.9 that way so i can read my afr using moates hulog and HTS.
https://www.hamotorsports.com/pages/obd1-ecu-wideband-installation-wiring-instructions
They say its possible. But i also read on this forum that its not possible..! So what must i believe?
I want to get it clear before i start buying anything..
Thanks
Old May 26, 2020 | 08:32 AM
spAdam's Avatar
Loved
Community Favorite
Default Re: Using Bosch LSU 4.9 wideband sensor, directly connected to ecu.
Depends on the ecu.
If it's an OBD1 Honda ecu as in the article you linked then the short, long, easy, and hard answers are all NO. What they are showing you in that article is a method for connecting your controller at the ecu reliably - Power, ground, & signal.
I suggest you read through this page to get a sense of how the LSU (and other lambda) sensors work, then you'll understand why:
How 5-Wire Sensors Work (Tech Edge)
Old Jul 6, 2020 | 07:06 PM
ERA_Evil's Avatar
Sorry to hijack, but wanted ask for insight on this. What controller could be used? Since i have a demon 2 with bluetooth, it has the capability to take in the signal and display it via their android app, but say, for example the aem wideband gauge and controller, if I can have the value displayed without the gauge, are there any controllers for the sensor, that simply output a signal?
say, so I can use my own gauge or the demon?
Old Jul 7, 2020 | 07:04 AM
spAdam's Avatar
Loved
Community Favorite
PLX. Their controllers are better than the other two big brands anyway.
downforlow
Engine Management and Tuning
11
Mar 15, 2009 06:12 AM
austinkli
Jun 21, 2008 11:11 AM
dustin
Mar 28, 2002 06:27 PM
ckkl
Mar 10, 2002 03:44 AM
