90 Honda Crx 5 speed(used to be auto)Cranking issues.
Old May 23, 2020 | 06:27 PM
Johnboy0620's Avatar
Default 90 Honda Crx 5 speed(used to be auto)Cranking issues.
Ok so I have a 90 Honda crx with a swapped engine. We had it running after the swap but I hardly drove it at all. Over time it eventually just stopped turning over at all. When I turn the key over all you hear is the starter click. If I jump the starter with a jumper it will turn over but not crank. Can anyone help me on where to start? I have had this car for 20 years. I have literally had the car tore all the way apart and redone it all besides like some relays here and there. I have most of the tools necessary To test the circuits.
Old Jun 23, 2020 | 04:33 AM
muellersfan's Avatar
Default Re: 90 Honda Crx 5 speed(used to be auto)Cranking issues.
Painted engine bay -- Use a thread restorer to thoroughly clean the three important engine bay grounds (G101 thermostat, G3 transmission, G1 battery).
Also check the clutch pedal starter switch.
FalkenSiR
Oct 8, 2006 03:05 PM
Rocky's_CRX
Dec 30, 2005 01:31 PM
Yellow Dragon
Aug 8, 2001 11:27 PM
