Wont go into gear
Old May 23, 2020 | 02:11 PM
Fantom0's Avatar
Default Wont go into gear
I have a del sol with a b20 swap, it's got a hydraulic clutch. The throw out bearing went bad but was still drivable, I went ahead and decided to replace it. I replaced the clutch, flywheel and everything else while I was at it. I even put on a new slave cylinder and bled it out and it looks to work perfectly. After I replaced everything I went to try it out, I started it up and tried to put it in gear but it doesn't want to go in any gear, and when I try reverse it almost makes a grinding noise. With all that replaced and the car working perfectly fine before, what could be my problem?
Old May 23, 2020 | 07:54 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Wont go into gear
Take a look at the release arm and make sure that when the clutch pedal is depressed, the release arm should move nearly 3/4". Also, is the release arm basically centered in the square opening of the clutch housing ? If it is not, there may be a problem with the pressure plate diaphragm.
Derek Malone
Transmission & Drivetrain
Apr 24, 2019 03:16 PM
romi_rome
Feb 21, 2015 08:43 PM
Skeero
Oct 18, 2011 07:23 AM
250r king
Feb 16, 2009 05:35 PM
boostedeghatch
29
Jan 3, 2009 12:20 PM
