Troubleshooting: Tachometer bounces around 5k-7k. Signal issue?
Old May 21, 2020 | 07:56 PM
purposebuilt's Avatar
Default Troubleshooting: Tachometer bounces around 5k-7k. Signal issue?
Hi I have a 96 gst with a b20 vtec in it and when I'm in vtec and above 5k the tach starts bouncing around in between 5k and 7k. Dose any one know what it might be I have no codes. Thanks
Old May 21, 2020 | 09:47 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default re: Troubleshooting: Tachometer bounces around 5k-7k. Signal issue?
Weak ICM in your distributor. If you have an aftermarket distributor, this is almost certainly your issue. Check your ignition coil as well.
Old May 23, 2020 | 12:57 PM
I have the oem gsr distributor
Old May 23, 2020 | 01:37 PM
TheShodan's Avatar
Moderator
Default Re: Tach bouncing around 5k-7k
That means the ICM in the OEM distributor you have is weak. you can change it with another or use an upgraded internal one from ACCEL .
Old May 26, 2020 | 04:36 PM
accel that dont make icm they make coils so I ordered one and I also have another oem igniter so I'm gonna try both of those hopefully it fixes the problem.
Old May 26, 2020 | 08:06 PM
TheShodan's Avatar
Moderator
Apologies. I meant Accel coil.
ALL components labeled so that we're on the same page
Old May 29, 2020 | 05:51 AM
so you think I can just change the coil I dont need to change the icm
Old May 30, 2020 | 05:40 PM
TheShodan's Avatar
Moderator
I'm saying try the coil first and see if thar helps. if not, change the ICM ignitor.
This is step-by-step.
Old Jun 6, 2020 | 05:42 AM
I bought the accel coil and I just realized it's a Chinese distributor so you think it be a safe bet to swap out ignites for the oem Hitachi igniter too
Sharky NRK
Jun 27, 2004 06:33 AM
hondaeg8
14
Jun 8, 2004 01:01 PM
SleepnCiViC
14
Jan 16, 2004 05:46 PM
CimorelliCRX
Mar 18, 2003 07:20 AM
CimorelliCRX
Mar 11, 2003 03:54 PM
