D16Z6 Stock Connecting rods maximum compression ratio.
Hey everyone,
I want to know if the d16z6 stock rods wil hold a compression ratio of 12.5:1?
I have the plans to let them cryo treated, but i want to know if thats realy necessary.
Thanks.
Thanks.
Thankz for your answer. but when i read here, 220hp on boost is a different force then a cr of 12.5:1 right?
what when 7 pounds of boost will be compressed? Will it also be a around 12.5:1? less i think?
Your over thinking it. My d17 stroker has stock rods and arp rod bolts, 11.5 to 1 comp and got revved to 8250 on the dyno and never had a hiccup. They will be fine.
9.6:1 vs 12.5:1 is a 30% increase in compression of, let's assume atmospheric pressure (14.7psi). 7psi from a turbo is almost 50% increase from atmospheric. this is just back-of-the-napkin reckoning for gut-check. but i think it's good enough.
xXx Justin xXx
May 15, 2003 09:42 PM
