Suspension & Brakes Theory, alignment, spring rates....
Stuck right caliper ?
Old May 16, 2020 | 10:48 PM
LukasGreen's Avatar
Default Stuck right caliper ?
Hi, new here and i need your help.
I'v got an civic eg6 with abs.
I replaced all around brake front system. Brake master cylinder, hoses, caliper sealing, pins, caliper piston , rotor and pads.
Unfortunately right caliper gets hot when i'm driving. Left caliper is ok.
When i'm braking the car goes sideway-to the right.
When i chceck the caliper it seems the right caliper piston goes (returns) less (backwards) from pads while i'mbraking than left caliper.
The left caliper piston goes (return) nicely "far" from pads.
What could be wrong ? Old bad abs module ? Old bad steel pipnig ??
Thank you guys
lv6l
Jun 3, 2013 11:52 PM
Waldron Racing
May 3, 2013 02:42 PM
DjBij099
Sep 3, 2008 09:04 PM
meotch
Sep 20, 2006 03:59 PM
James
Jul 13, 2004 06:54 PM
