Clutch Safety Switch blues 911 Covid free
Old May 14, 2020 | 02:58 PM
CRXSTRUGGLE's Avatar
Default Clutch Safety Switch blues 911 Covid free
Well, car won’t start, took out the starter passed 3 times,,, new battery,,, new Alternator,,,
if I pop the clutch she runs looked a 308
if I step on the clutch to try and start her nothing
the rubber stopper came off so if I hold the switch in with my finger and turn it over it just clicks and does not start or turn over and try to start?
I have checked the fuses
HELP please Help, no idea what to do
and I can’t get my hand in there to remove the clutch switch to try and bypass it (any tips to remove it? )
should I scrap here and get a Toyota?
I need a expert
Old May 15, 2020 | 10:41 AM
CV19hoax's Avatar
Default Re: Clutch Safety Switch blues 911 Covid free
Remove the pedal and diagnose it?
Old May 15, 2020 | 12:45 PM
How do you remove the pedal?
Old May 15, 2020 | 01:00 PM
Old May 15, 2020 | 06:39 PM
Marcos Barrios's Avatar
to remove the clutch pedal you first have to loosen the clutch cable all the way and then theres a 14mm nut on the left side of it
but what you really need to do is see if your getting spark at the starter when your trying to start the car
disconnect the wire that goes to the solenoid on the starter
and make sure its getting 12 volts when your trying to crank the motor over
with the clutch pressed down
Old May 15, 2020 | 07:15 PM
Didn’t know you could take the clutch pedal off like that, got a photo of that assembly?
the car is getting spark, it runs, and starts when you pop the clutch...
what else could it be? I’m at a loss here
thanks anyone with a answer
Old May 18, 2020 | 04:32 AM
Mr. Self Destruct's Avatar
Try removing the plug from the back of the clutch switch and jumping it. That way you can at least rule out a faulty switch as the issue. 5 minutes and you'll know if the switch is the problem, or if you need to start looking elsewhere.
Old May 18, 2020 | 05:08 AM
Problem is my hand can’t fit in there to get to the switch...
im starting to think it’s the ignition coil it has gone out before 2 times, this would be the third
Eeness
Aug 31, 2017 04:51 PM
magicmyst98
14
Sep 2, 2013 12:06 PM
gustafse
Nov 27, 2011 04:55 PM
zerovandez
Apr 1, 2011 01:05 PM
GroundZer0
Aug 15, 2003 12:05 PM
