91 ex Cranks but no start? No cell or S light coming in (AT ALL)
Old May 13, 2020 | 03:51 PM
Brian Greentttt's Avatar
Default 91 ex Cranks but no start? No cell or S light coming in (AT ALL)
I f22a4 accord ex 91 is having a problem starting. It would start fine just a couple days ago. However after I had repaired the exhaust system it acts like it isn't getting spark. When I pull the plugs I smell gas so the pump seems to be working. The starter is definitely engaging as I can feel the engine crank rotating. but it seems like it's something electrical as my cel or my S light will not come on even in position "on" position or as I am trying to crank. I didn't mess with the ECU or TCU in working on the exhaust so I'm at a loss on what may have happened. Any ideas?
Old May 13, 2020 | 04:05 PM
Default Re: 91 ex Cranks but no start? No cell or S light coming in (AT ALL)
Solved... I remember I changed out some extra fuses I had with new ones when I bought an assorted pack. Turns out I out the driver side ECU fuse in the wrong slot. Haha. Haste makes waste
Old May 13, 2020 | 05:57 PM
99stockcivic's Avatar
Good job!
Old May 13, 2020 | 06:21 PM
Spoke to soon actually. Still isn't starting but I didn't look to much into it yet. So hopefully something simple cel is solid on and tried to jump it but I couldn't get blinks but maybe entered the jumper wire wrong. Take a look at it again soonish.
Old May 14, 2020 | 01:30 AM
Thermostat ground was off. Fixed it
Old May 14, 2020 | 09:30 PM
bloomin's Avatar
Thanks for following up!
So many people post a problem and NEVER follow up with the end solution if there is one.
Crucialambition
Nov 23, 2014 12:18 AM
91integragsr
Mar 26, 2012 08:16 PM
flyinbird
Feb 17, 2005 06:31 PM
smoothludey2
Sep 30, 2002 05:08 PM
