Oil on spark plug threads
Old May 13, 2020 | 10:54 AM
Bo Cantrell's Avatar
Default Oil on spark plug threads
Hello i have a f22b1 and i just replace my spark plugs my first one had oil on it but it was only on the threads of the plug there wasn't any on the boot or on the spark plug tube Walls all i can find a videos about the spark plug tube seal and i don't think it's that because of there not being oil in the tube
Old May 13, 2020 | 11:06 AM
99stockcivic's Avatar
Default Re: Oil on spark plug threads
First thing you want to replace is the valve cover and spark plugs seals (usually come together in a kit). They are about $10-$15. Not too bad a job to do.
If that doesn't fix it....then it could be much more difficult to fix, as that would lead me to believe valve seals or piston blowby or basically something in the engine that is worn.
Here's the link to a 2000 valve cover and spark plug grommet kit, I'm only guessing since you didn't list car or year or engine size. So, this is for a 4cyl, 2000 accord.
https://www.rockauto.com/en/catalog/...r+gasket,10710
Old May 13, 2020 | 11:15 AM
oh thought i put it in its a f22b1 97 accord engine in a 97 civc
Old May 13, 2020 | 11:20 AM
Anyway, same answer then, just find your year and replace the gaskets first.
Old May 13, 2020 | 11:41 AM
okay thank you folks im gonna replace those get a some of the blue mechanic napkins soak up the oil and i dont have any smoke blowing so i dont think its position rings again thank you. I will be back with up date.
potatointegra01
Apr 14, 2015 03:49 PM
mafia
Mar 26, 2010 10:13 PM
Red_Si
Oct 26, 2006 10:48 AM
fastcarsarestupid
12
Dec 8, 2004 09:42 PM
si91
May 28, 2002 07:33 AM
