1996 accord LX immobilizer issue. How do I remove the system?
Old May 12, 2020 | 06:47 PM
Lisa Sherman's Avatar
Default 1996 accord LX immobilizer issue. How do I remove the system?
My chip broke off inside the unit. It has worked fine, with a wiggle every now and then, until today. My car will not start. I need to remove the device. I can't find anything about the system, only the alarm... Which I don't have.
Old May 12, 2020 | 06:53 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: 1996 accord LX immobilizer issue. How do I remove the system?
A 1996 Accord does not have the Honda Immobilizer System.
Describe in detail what you're referring to: chip, unit, etc.?
Old May 12, 2020 | 06:59 PM
hondaslave1342's Avatar
are you sure it's a 1996
Old May 12, 2020 | 07:51 PM
99stockcivic's Avatar
I was going to ask the same. I thought it was only from 1998/1999 forward.
However, If you do haven immobilizer, then I would install a immobilzer bypass chip.
https://www.ebay.com/itm/Immo-Emulat...cAAOSw7gZa6ssc
How to install it is here:
Old May 13, 2020 | 10:05 AM
the chip looks like the one in the picture. I guess they call it an interrupt, not an immobilizer! Sorry!
Old May 13, 2020 | 04:54 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Generally, installation of the starter interrupt require the cutting of the wire going to the starter.
For a 1996 Accord, they probably cut somewhere along the Blk/Wht wire that runs from the ignition switch to the under-dash fuse box. Follow the wires from the interrupt to find where they cut the Blk/Wht wire. (The Blk/Wht wire is a black colored wire with a white stripe running through it.) The Blk/Wht wire starts at the 7-P connector plugged into the ignition switch, and runs along the wire harness to the 7-P brown connector (C906) at the under-dash fuse box. You'll want to reconnect or splice the Blk/White wire back together wherever it was cut.
Old May 13, 2020 | 11:42 PM
Thank you, will check that out tomorrow
Old May 14, 2020 | 05:03 PM
That worked! Thank you so much!
Old May 14, 2020 | 05:42 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Great to hear. Thanks for coming back to tell us it was resolved.
Old Mar 14, 2022 | 02:05 PM
1OldDog's Avatar
Tech8; is this a certain fact? I really have to know for sure.
My '96 Accord has a factory installed Honda Anti-theft system P/N 08E51-SV4-100-F
Something is causing the car to not turn over at times so I need to rule this out.
The car starts right up most of the time. Yesterday, all I got were dash lights, no crank. I proceeding to hold down the 'disarm/valet switch", located under the dash, for 5 seconds and then the car started right up.
Another time, when it would not turn over, I pressed on the buttons on this transmitter fob and the car started.
If my security system is NOT tied in to the ignition system then all this button pushing activity I did was coincidence?
Can you help me out over here please? Thank you
Old Mar 14, 2022 | 03:47 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
1996 North American Accords do not have the Honda Immobilizer System. To not confuse people researching in the future and to separate the issues, please make a new separate thread for your issue. Generally, to continue with a new issue is considered thread jacking.
I will close this thread.
nhldogg
Feb 19, 2010 02:14 PM
R_ACE1
Jun 18, 2009 04:53 AM
in4mation
Aug 14, 2006 09:18 AM
