1996 accord LX immobilizer issue. How do I remove the system?
My chip broke off inside the unit. It has worked fine, with a wiggle every now and then, until today. My car will not start. I need to remove the device. I can't find anything about the system, only the alarm... Which I don't have.
Re: 1996 accord LX immobilizer issue. How do I remove the system?
A 1996 Accord does not have the Honda Immobilizer System.
Describe in detail what you're referring to: chip, unit, etc.? |
Originally Posted by Lisa Sherman
(Post 52176783)
I was going to ask the same. I thought it was only from 1998/1999 forward.
However, If you do haven immobilizer, then I would install a immobilzer bypass chip. https://www.ebay.com/itm/Immo-Emulat...cAAOSw7gZa6ssc How to install it is here: |
Originally Posted by tech8
(Post 52176784)
Describe in detail what you're referring to: chip, unit, etc.? https://cimg0.ibsrv.net/gimg/honda-t...09510272ca.jpg |
Generally, installation of the starter interrupt require the cutting of the wire going to the starter.
For a 1996 Accord, they probably cut somewhere along the Blk/Wht wire that runs from the ignition switch to the under-dash fuse box. Follow the wires from the interrupt to find where they cut the Blk/Wht wire. (The Blk/Wht wire is a black colored wire with a white stripe running through it.) The Blk/Wht wire starts at the 7-P connector plugged into the ignition switch, and runs along the wire harness to the 7-P brown connector (C906) at the under-dash fuse box. You'll want to reconnect or splice the Blk/White wire back together wherever it was cut. https://cimg7.ibsrv.net/gimg/honda-t...505a1216e2.jpg https://cimg3.ibsrv.net/gimg/honda-t...70ac482e2a.jpg |
Thank you, will check that out tomorrow
(Post 52177570)
Great to hear. Thanks for coming back to tell us it was resolved.
(Post 52176784)
My '96 Accord has a factory installed Honda Anti-theft system P/N 08E51-SV4-100-F Something is causing the car to not turn over at times so I need to rule this out. The car starts right up most of the time. Yesterday, all I got were dash lights, no crank. I proceeding to hold down the 'disarm/valet switch", located under the dash, for 5 seconds and then the car started right up. Another time, when it would not turn over, I pressed on the buttons on this transmitter fob and the car started. If my security system is NOT tied in to the ignition system then all this button pushing activity I did was coincidence? Can you help me out over here please? Thank you |
Originally Posted by 1OldDog
(Post 52556489)
Tech8; is this a certain fact? I really have to know for sure.
My '96 Accord has a factory installed Honda Anti-theft system P/N 08E51-SV4-100-F Something is causing the car to not turn over at times so I need to rule this out. The car starts right up most of the time. Yesterday, all I got were dash lights, no crank. I proceeding to hold down the 'disarm/valet switch", located under the dash, for 5 seconds and then the car started right up. Another time, when it would not turn over, I pressed on the buttons on this transmitter fob and the car started. If my security system is NOT tied in to the ignition system then all this button pushing activity I did was coincidence? Can you help me out over here please? Thank you I will close this thread. |
