1993 honda del sol SI,A/T.the car has new calipers at all 4 corners,new brake hoses and master cylinder and pads.it will go about 4 miles before the front brakes lock up and pads start to smell like they are burning and you call the tow truck for a ride home.any ideas on what to check /replace next?
Did you check the master clyinder push rod clearance adjustment before installing the master clyinder? The service manual requires that check as well as a brake pedal height check and brake pedal freeplay check after a master clyinder installation.
Were the brakes locking up before you changed the calipers, new brake, hoses, master cylinder and pads? Or did it just start occuring after you changed everything?
If it just started after the work, you just need to painstakingly recheck everything. Something appears to be causing the pads not to slide back.
I mentioned the master clyinder push rod clearance adjustment as something to check because the rod can cause brake drag if it is adjusted to long.
