ITR intake mani on b16
Old Nov 15, 2002 | 01:47 PM
project-hatch's Avatar
Default ITR intake mani on b16
I have a 00 Si head on my b16. I was wondering if getting an ITR intake mani instead of the 00 Si one I have on it now will make a difference? Any help will be great.
Old Nov 15, 2002 | 02:06 PM
.(Lazarus).'s Avatar
Default Re: ITR intake mani on b16 (project-hatch)
It makes noticably more power than stock, but the JGEdlebrock manifold is even better for about the same money
Old Nov 15, 2002 | 02:57 PM
ULTRA911's Avatar
Default Re: ITR intake mani on b16 (ATXhybrid)
the jg costs way more than the itr.
Old Nov 15, 2002 | 03:30 PM
I can get an ITR for around $200, so I thinks its quite abit cheaper than a JG
The Mole's Avatar
Default Re: ITR intake mani on b16 (ULTRA911)
thank you
chris
Old Nov 16, 2002 | 10:18 PM
KayOs's Avatar
Reaping the maximum benefits from an ITR or SKUNK2 intake manifold requires you port match your cylinder head to intake manifold. You will see results at high RPM's, otherwise don't bother installing one.
Old Nov 19, 2002 | 12:05 PM
Kataku2K3's Avatar
Do you have anything done to your B16???
It makes noticably more power than stock , but the JGEdlebrock manifold is even better for about the same money
You are saying that an ITR manifold on a B16 is going to make noticably more power??? Dyno plot please!! Maybe with some cams and pistons, but not a whole hell of a lot with a stock motor
[Modified by JDMspecEG6, 1:07 PM 11/19/2002]
Old Nov 19, 2002 | 04:33 PM
KayOs's Avatar
Default Re: ITR intake mani on b16 (JDMspecEG6)
You will see results only if at the minimum you have a ported and polished head. Remember that the ITR and skunk2 manifold have longer runners, this is meant for high RPM advantages. If you are not generating enough high RPM power then its not worth your time installing ITR manifold.
Ported and polished head should also mean an accompanying power head setup such as higher lift cams, cam gears, valve job.
Old Nov 19, 2002 | 05:10 PM
madhatter07's Avatar
Default Re: ITR intake mani on b16 (KayOs)
i dont know if any of you guys saw this but in an old issue of HCI (hot compacts and imports, im not sure their still around) theydid a test on a B16 about the TYPE R intake man. and found thatthe B16 manifold was a lot more effective because the Type R didnt make any more power until like 200 RPM before redline. I cant find the issue that i saw it in but i believe they had the B16 man. hone matched or something like that. Im not sure how much thatwould cost though, would it be cheaper?
Old Nov 20, 2002 | 03:25 PM
SIXTYdashONE's Avatar
HT's Biggest Loser
Default Re: ITR intake mani on b16 (madhatter07)
just go buy it, you know yer gonna anyways, and u may feel a little difference, but not alot..
Old Nov 25, 2002 | 05:40 PM
StorminMatt's Avatar
Actually, longer runners are better for low RPM power.
Old Nov 25, 2002 | 06:15 PM
Kataku2K3's Avatar
Default Re: ITR intake mani on b16 (StorminMatt)
I do have to admit that even if it doesn't make any power over stock the ITR still looks better.. To me the 99-2000 Si looks the best for the B16's but i still don't like them.... the SK2 looks like it is made really cheap.... First of all i would just get a CTR intake cam you'll be able to get power out of that easier than a manifold... Peace
[Modified by JDMspecEG6, 7:16 PM 11/25/2002]
Old Nov 25, 2002 | 07:58 PM
stockegsix's Avatar
i like how the ITR manifold looks too.
Old Sep 13, 2003 | 09:06 AM
JALOP B16's Avatar
Default Re: ITR intake mani on b16 (zzZZzzleeperCX)
What about on a 1st gen b16? Is it worth it?
Old post I know.
Old Sep 13, 2003 | 08:22 PM
Patch's Avatar
Default Re: ITR intake mani on b16 (JALOP B16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JALOP B16 &raquo;</TD></TR><TR><TD CLASS="quote">What about on a 1st gen b16? Is it worth it?
Old post I know.</TD></TR></TABLE>
Not on stock cams.
Old Sep 14, 2003 | 05:00 AM
VTECVillain's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KayOs &raquo;</TD></TR><TR><TD CLASS="quote">If you are not generating enough high RPM power then its not worth your time installing ITR manifold.</TD></TR></TABLE>
Agreed.
King V
Oct 3, 2007 11:03 AM
mrbsponge
Sep 26, 2005 10:32 PM
b19coupe
Jan 5, 2004 11:36 AM
