opinions needed. Gsr build vs ls with gsr internals. Which to go with?
Old May 5, 2020 | 02:13 PM
purposebuilt's Avatar
Default opinions needed. Gsr build vs ls with gsr internals. Which to go with?
Hi I have a complete gsr bottom end and a ls block and I was woundering if there an advantage of building a ls with gsr internals or just building the gsr. I will be building it with eagle rods and nippin jdm p73 pistons. Any help would be appreciated on wich route to take.
Old May 6, 2020 | 11:15 AM
TheShodan's Avatar
Moderator
Default re: opinions needed. Gsr build vs ls with gsr internals. Which to go with?
Why not use the LS Internals in the GS-R? I did that 10 years ago with wonderful success. Got great torque, no VTEC "Conversion" nonsense, and everything integrates well.
I haven't driven the car in almost 2 years due to work, but here's the information if you're interested at.
Project EM1 - The Shodan goes NA..
Old May 7, 2020 | 05:50 AM
Ej1_87's Avatar
did you boots your setup?
Old May 7, 2020 | 03:35 PM
I dont have a ls crank and rods just a ls block and gsr internals. To put the gsr internals in a b18b does anything have to be modified (ie notching or anything)or is it just like building a b18b just with gsr internals
Old May 7, 2020 | 03:47 PM
Ej1_87's Avatar
Check your deck height because if I'm not mistaken the LS deck height is shorter than the GSR. Might be able to make up for it with the GSR internals. Use the zealautowerks.com compression calculator to see where you'll be at for compression. Oh and dont forget that girdle. While your at it might aswell have everything balanced.
Old May 7, 2020 | 07:13 PM
Yeah I did with jdm itr pistons it's around 12.5:1 compression. Is there anyone out there that has personally put gsr internals in a ls block
Old May 7, 2020 | 09:27 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
GSR internals can be installed into an LS engine block without any major modifications. No block notching or clearancing.
Old May 8, 2020 | 01:01 AM
Cool thanks. Also when wheni use the compressor calculator the ls compression is .7 pts hier them the gsr block. Is that correct and why is that. It dosent matter to me but just woundering. Because I'm use nippin jdm itr piston with in the ls it's around 12.5:1 and the gsr its 11.7:1. Also has anyone ever used nippon piston the say they have deeper valve pockets then standard oem pistons so you can run big cams. Is this true
Old May 8, 2020 | 03:50 AM
Ej1_87's Avatar
that's because of the shorter deck height if the ls block.
Old May 8, 2020 | 06:42 AM
TheShodan's Avatar
Moderator
It wasn't cold enough to need boots..
I kid. I kid.....But no, this was strictly my NA Project.
Old May 8, 2020 | 06:50 AM
Ej1_87's Avatar
I have a GSR block with LS crank and rods and ITR pistons (Puts me at 11.3:1). Checking to see if anyone has run boost on this type of setup with success.
Old May 8, 2020 | 02:40 PM
TheShodan's Avatar
Moderator
Default Re: Opinions needed: Gsr build vs ls with gsr internals. Which one to go with?
I'm sure its been done, but not at that compression on a stock rod and a cast piston. cylinder pressures get too hot, even intercooled.
Old May 8, 2020 | 02:51 PM
Ej1_87's Avatar
Default Re: opinions needed. Gsr build vs ls with gsr internals. Which to go with?
I've got scat rods n NPR itr pistons... 1st ring at .20 2nd at .25..... I'm thinking of going with a gt28 nothing bigger.
T9U4ReBgO
Oct 23, 2007 02:46 PM
AEMintegra22
Jun 24, 2006 09:42 PM
slambedcivic
Jul 14, 2005 05:05 AM
koucex
Jan 19, 2005 08:28 PM
