Running Bad after Wideband
Old May 2, 2020 | 08:50 PM
AMoody311's Avatar
Icon4 Running Bad after Wideband
Hello, I'm new here so I apologize if I miss anything. I have a EG Hatchback with a GSR swap on Hondata s300. It has always ran perfect up until I installed an AEM Wideband. I have the Wideband pinned into D10 in the ECU and the sensor in my Skunk2 Alpha header. The main problem I have is the AFR is all over the place. When driving until throttle it's fine. But as soon as I start cruising it jumps all the way from 12 to 20 and starts breaking up until I give it throttle again. It does this until the CEL comes on for Engine Overtemp Condition then it runs perfect. Any help is appreciated!
Old May 3, 2020 | 01:36 PM
wunfstgsr's Avatar
Loved
Community Favorite
Default Re: Running Bad after Wideband
Are you running in open or closed loop?
Make sure the lambda conversion table is correct for using the AEM wide band, read through this link and make sure you cut the resistors in the ECU as well as use the thermostat ground for the wide band ground.
http://www.phearable.net/information...etupguide.html
Old May 3, 2020 | 02:49 PM
NVturbo's Avatar
O.G. triple O.G.
You're SUPPOSED to wire it to D14, not D10. That may be your issue right there.
Old May 3, 2020 | 05:03 PM
wunfstgsr's Avatar
Loved
Community Favorite
Actually its better to use D10! If you searched the Hondata forums you would see why. D14 does not have the full range of voltage needed for a 0-5 volt input. so use D10.
Old May 3, 2020 | 05:08 PM
NVturbo's Avatar
O.G. triple O.G.
Found an article describing the issue on HAMotorsports' website.
However, this is what they later mentioned.........….
"UPDATE: With all newer wideband systems that use the Bosch LSU 4.9 sensor, 0-3.73 volts reading through the stock D14 O2 sensor input is more than sufficient for reading air/fuel ratio, so using the D10 ELD input is no longer beneficial. If your wideband uses the Bosch LSU 4.9 sensor, we recommend using the D14 input now, this way you can leave the ELD circuit functional."
Old May 3, 2020 | 06:07 PM
wunfstgsr's Avatar
Loved
Community Favorite
Well there you go!
chewyv
Engine Management and Tuning
Apr 17, 2017 07:19 PM
90efmexstyle
Jan 9, 2008 04:49 PM
IMPORTMyth01
Apr 9, 2006 04:57 PM
92WhiteEG
Feb 10, 2005 11:15 AM
GruvyTune
May 24, 2002 02:39 PM
