Bad Competition Clutch? Stage 4 6-Puck
Hey guys so just had my car (2008 Civic Si FA5) serviced for a new Stage 4 CC 6 Puck clutch and noticed it makes a weird noise when accelerating through the gears. Only happens on acceleration. Starts in gears fine and everything. No problem or noise there. Just happens when I accelerate. Only driven it for less than 200miles. Any advice or idea what this might be? Any help would be appreciated. Thanks.
power adder? What do you mean by this exactly?
but yes new flywheel and hardware.
the noise is more of a vibrating noise than anything else. I’m going to lift the car today and check for any loose suspension pieces or any other oddities. I think it may also be my struts. They are completely shot and the lowering spring on the FL wheel is snapped in half due to a accident the prior owner got into. I just recently found out about this so I purchased new coilovers and will be installing them soon. Hopefully this will solve the vibrating noise because I think it’s suspension related. Talked to the shop that installed my clutch and they believe it’s the suspension as well.
I’ll give an update once the coils are on.
