Honda d16z6 bad idle
Old Apr 28, 2020 | 05:20 AM
Aaron Axford's Avatar
Default Honda d16z6 bad idle
Hey guys. So im new to posting on here but the time has come. I’m in need of a bit of help.
I originally had the d16y7 the head basket went so I decided to swap for the d16z6 the actual swap went okay wasn’t too many problems lol.
ever since tho I can’t seem to get it to idle as it should it use to want to die when just sat there on idle was such a pain to drive. I then squeezed the fuel return line and instantly idled better and I was able to drive it normally. I thought I’d fit a universal fuel pressure regulator. Set it at the about 37/40 psi and yes it doesn’t die on idle but still the idle is rough and it does bog for a second when I put my foot down.
id appreciate any help just to point me in the direction to look at first.
many thanks guys
Old Apr 29, 2020 | 11:17 AM
Breckin Meyer's Avatar
Default Re: Honda d16z6 bad idle
Sometimes an idle issue can just be the fact that the engine is dirty. My '94 Integra GS-R with a B16A2 swap wouldn't start or idle on its own so I cleaned out all my intercooler piping along with the intercooler itself, the idle air control valve, air filter, and throttle body..now she's back to purring like a kitten. This isn't a guaranteed fix to your problem, but there's a good chance it can help.
Old Apr 29, 2020 | 09:27 PM
Hi thanks for getting back to me. I could understand that the is dirty has been sat for a while but. I’ve done everything you have mentioned. Like I mentioned in the first post if I squeeze the fuel return line then it will idle properly Or better should I say. so has be something To do with fuel lines or something along them lines surly.
many thanks Aaron
defkid999
Oct 17, 2006 10:12 AM
hidden sol
Oct 16, 2006 09:53 PM
Efil4zaggiN
Dec 17, 2004 07:32 PM
civbeater90
Feb 28, 2003 04:45 PM
