Hey guys. Running into a problem. I'm not able to find any replacement for the breather boxes. This is for a b16a2 engine. Unsure if I'm just not searching the right words. Tried breatherbox, oil separator, breather canister. Would somebody mind helping me out? Trying to get this replaced or find a solution for a delete if possible. motor is boosted with a lil turbo. Any help would be appreciative, I've spent a couple hours searching but apparently I'm blind or I can't find an OEM replacement.
Or if you want to upgrade for a replacement to accommodate the extra HP from the Turbo you can get this full 100% bolt on kit, I use this on my boosted setup.
Where does the PCV valve go on this kit wunfstgsr ? Is there a provision to allow the oil trapped in the can to drain back directly into the block like the original breather box or do you have to do it manually through the petcock pictured ?
It replaces the entire Black box and PCV system.
It does not have a drain back and has a plug on the bottom to drain it manually which I prefer. I recently drained mine and it had lots of condensation and oil looked pretty ugly. I further incorporated a Volvo check valve like TheShodan has on his kit into this system and I explain how and where I installed it here,
