B16 swap questions
Old Apr 17, 2020 | 02:16 AM
Joshcarman93's Avatar
Default B16 swap questions
I just recently got a jdm b16a and it comes with a rhd harness. I’m swapping it into 97 cx. the motor is obd2a with a p2t ecu I am having trouble finding the correct harness to use because I am trying to keep the p2t ecu
Old Apr 17, 2020 | 07:57 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: B16 swap questions
Use the original '97 CX engine harness found in the car. Modify it to fit the plugs on the JDM B16A engine. Purchase an OBD-2A->2B ECU adapter harness so that you can plug in your P2T ECU. This is not an ideal solution.
h22_crx
Aug 10, 2007 10:10 PM
leesi
14
Jul 5, 2005 07:51 AM
skmonkey27
Jan 17, 2005 06:52 AM
wooderson
Apr 30, 2003 08:59 AM
roc109
Nov 24, 2002 09:00 PM
