Camshaft Choices - 500whp LS-V
Old Apr 16, 2020 | 08:44 PM
digital sol's Avatar
Default Camshaft Choices - 500whp LS-V
Hello, I wanted to inquire the masses and see what a recommended camshaft is for
my setup. The motor I purchased comes with BC turbo camshafts but I’ve done some research and heard some horror stories about them snapping and such.
This is just a street car build with 500whp as the goal on pump and what ever I can make on c16 (whatever my fuel limitations are). Weekend warrior build that will see minor track time. Head:
B16
Super tech flat valves
Skunk2 Pro valve springs
Skunk2 Pro retainers
Skunk2 LMA’s
Ported and Polished
3 angle valve job
Brian crower stage 2 turbo camshafts
Brian crower adjustable cam gears
Ls block
Golden Eagle sleeved (82mm/oring)
Aries piston (10:1)
Upgraded wrist pins
Manley turbo tuff ibeam rods
Turbo:
STC interceptor, .63 ar
LoveFab sidewinder B series manifold (a2w setup)
Tial 44mm WG
Greddy Type S BOV
Misc:
Skunk2 Ultra Street manifold
Skunk2 70mm TB
Fuel:
Undecided pump, currently have a walbro 255
ID injectors (havnt decided size, 1000 minimum)
Transmission:
GSR trans
Mfsctory LSD
Carbon sycros
Ls 5th gear
Goals - 450-500whp on pump, 500+ c16
(Two tunes)
wrote this on my phone so ignore any typos
Thanks
Old Apr 16, 2020 | 09:37 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Camshaft Choices - 500whp LS-V
Improper installation would be the only reason a camshaft fails... regardless of what brand they might be. I have been using BC products for as long as they have been an entity and have NEVER had a problem. There is no factual reason to be afraid of those camshafts.
Old Apr 17, 2020 | 01:21 AM
extremeracer's Avatar
There's nothing wrong with the BC Turbo cams and they are bigger than B16A cams. It's just been shown that GSR/ITR/CTR cams actually make more power than these "Turbo grinds" from BC and Crower. Proper B-series turbo cams from GSC and Kelford only appeared on the market much later and shouldn't be grouped with the above statement.
I know of many 2JZ guys locally using BC cams and valvetrain and they're a solid, high value product.
Since you already have them, run them...the primary lobes are larger than the OEM Honda cams so your VTEC switchover isn't as aggressive and they should make more torque and mid-range power. If you don't hit your power goals then look into something like a GSC T1/Skunk2 Pro 1/Kelford B
Old Apr 17, 2020 | 01:35 AM
GEN2 LS's Avatar
Loved
I'd go with some Skunk2 Tuner1's. Seem to be the camshaft of choice.
Old Apr 17, 2020 | 12:59 PM
Thanks fellas!
I am going to just keep them in for now. The motor is fully assembled but never turned over. As mentioned if I don't make my goals ill look at the GSC cams but rock what I have for now. Plenty of other things I need anywho before i upgrade or change things around more.
Old Apr 17, 2020 | 05:02 PM
Nathan937's Avatar
At that level, the Sk2tuner1 would be a good pick. Or a ITR/CTR if you can find a set reasonable.
Old Apr 20, 2020 | 03:13 PM
LightningTeg's Avatar
Community Builder
ITR
"keep it simple stupid"
LsVtecEj1Milano
33
Feb 14, 2014 01:55 PM
H22*CiViC
Nov 5, 2010 10:42 AM
kidd_drastic
31
Jan 28, 2006 10:05 AM
93c1sol
Jan 11, 2006 08:54 PM
b18bEG
Oct 14, 2003 06:15 AM
