Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
07 civic ex LIMP MODE
Old Apr 15, 2020 | 04:11 PM
Soorm23's Avatar
Default 07 civic ex LIMP MODE
The codes read p0300, p0304, p306, p0305, p0400. I've run the codes several times after resetting. It consistently comes up with p0300, p0304, p0306, p0305. I have replaced all of the spark plugs and wires. The MAF has been replaced, as well as the air filter. I can't wrap my head around whats going on. It idles beautifully and revs the engine (in neutral or parked) perfectly. That being said, When I put it in drive, it will go fine for a short time (until I get to 20 mph). You can tell the entire engine shakes along with the misfire engine light flash while going 15-20 mph. My rpms won't go over 2000-2100. By the time i get back, the engine is barley running. Wont go above 5 mph
2007 civic ex 130,000 3rd motor because 2nd motor had this problem also
05ex
Honda Civic (2001 - 2005)
Aug 21, 2015 04:41 PM
derjac
May 24, 2010 01:46 PM
Cheetah51
Mar 13, 2009 01:57 PM
vorovsky
16
Aug 3, 2003 12:59 PM
