Crank no start unless brake cleaner ?
Old Apr 14, 2020 | 10:13 AM
Edwin Aviles's Avatar
Default Crank no start unless brake cleaner ?
So I have 98 civic with d16z6 swap and the issue I'm facing right now is that when I spary brake cleaner into the manifold it'll start right up but then die. I did a lot to get it to start like I already replaced the distributor, spark plugs and wire and did the obd2 to obd1 fuel injectors cause it wasn't giving spark so that issue is kinda solve cause now when I play around with the distributor it slick wants to start but won't and I don't know if vacuum has to do anything cause I left open till I found a correct diagram for it.
(Sorry this is my first swap so I'm lost here!)
Thank you for your time!!
Old Apr 14, 2020 | 05:36 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: Crank no start unless brake cleaner ?
You already got it narrowed down to fuel. She fires up when you spray flammable aerosol down the IM. That means you have spark and compression. Then she dies cuz no fuel.
You have a fuel problem, maybe your obd2 to obd1 injector setup?
Old Apr 15, 2020 | 06:33 AM
hey bro sorry been busy but I follow the fuel injector diagram for the wiring setup so I don't believe it would be that issue unless its different for d16z6 and im going to the junk yard Thursday to grab some obd1 injectors but is there a way to check it cause there quite different ways to do it but I wanna know the best way to do it and if I was to switch back to obd2 would it work better?
Old Apr 15, 2020 | 06:42 AM
NVturbo's Avatar
O.G. triple O.G.
check your GROUNDS. Dealt with this in my cousin's H22 swapped Accord.
Old Apr 20, 2020 | 10:14 AM
Hey sorry I took long to respond but same issue came and I added 4 more ground cable so I'm lost at this point but now its not even cranking unless I put it on first gear 😔
Old Apr 20, 2020 | 07:25 PM
muellersfan's Avatar
Does the fuel pump prime?
Do the fuel injectors spray fuel when cranking the engine?
Old Apr 21, 2020 | 07:09 AM
tony_2018's Avatar
Fish Twig
This
Old Apr 29, 2020 | 09:21 AM
Manuel Campos's Avatar
Having the same problem no buzzing from the main relay and fuel pump dont prime
SmoothCTR
May 30, 2012 07:28 AM
foxracer677
May 11, 2011 08:24 PM
unrealgtx
Sep 20, 2007 08:16 PM
gLotex70
May 31, 2003 01:30 AM
