On 2001 Accord ex v6 what wire out of pcm controls temp gauge?
Old Apr 13, 2020 | 12:13 PM
2001accordexv6's Avatar
Default On 2001 Accord ex v6 what wire out of pcm controls temp gauge?
Hello I see on the 2001 4 cylinder accord the wire that goes to the temp gauge connector(c2 yellow/green) from the pcm is blue connector c24 (yellow/green) at pcm but on my v6 blue pcm connector that spot is blank.what wire goes from the pcm to the temp gauge on the v6?and we're does it tie into the temp gauge?I know the ect sensor goes into pcm at c26(blue connector at pcm)but from there I'm lost.there is no temp sending unit on this model so how does it get from pcm to gauge?thanks guys any input or wiring diagrams are very much appreciated.
question 2_ is anything else other then just the temp gauge going into c2 at cluster connection ( right side connector of cluster yellow/green wire) ? if my short is from pcm to cluster can I snip that wire and run from pcm (????) to c2 at gauge?) thanks guys
2001accordexv6
Apr 13, 2020 10:40 AM
Brandon Rayner
Jun 8, 2016 06:28 AM
93coupe91hbTY
Oct 5, 2015 05:01 PM
acaliguy
Jan 27, 2013 08:28 AM
hondaaccordf23
Jul 30, 2012 12:24 AM
