AWD Conversion Forum This forum is to help with the recent advent of new AWD conversions. Got a question? Ask it here. Got an answer? Drop the knowledge here
AWD for 1k
Old Apr 7, 2020 | 05:04 PM
tigArex's Avatar
Default AWD for 1k
Going awd on the cheap... Going to be making any parts I can to try and keep the build under 1k.
Parts purchased
  • transmission/transfer case
  • land rover drive shaft
  • crv rear diff and axles
Parts to make or buy
  • trailing arm
  • fuel cell
  • exhaust
  • rear differential mount
  • welded differentials
  • shifter/cables
I work at a sheetmetal shop and plan on modifying old part to work with my current set up. I have an ls/vtec crx with about 500hp and $350 left on my budget.
started the project a couple months ago.
pinned differential
picked up some trailing arms hoping to trade later for something I need.
$50 but are in terrible shape
Hoping to be finished by mid summer.
Old May 3, 2020 | 02:52 PM
tigArex's Avatar
Default Re: AWD for 1k
currently have one short and long axle so I'm going to be stretching the rear by 3". I bought a 2nd set of trailing arms and will be shrinking them about 2" to better fit two short axles.
Old May 3, 2020 | 03:06 PM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
Dynasty Crew Check-In!
Old May 3, 2020 | 03:50 PM
Ryanthegreat1's Avatar
Welded up the dual pump to use a viscous coupler from a range rover?
Old May 3, 2020 | 05:36 PM
tigArex's Avatar
Yes
Old May 3, 2020 | 06:39 PM
tigArex's Avatar
going to beef up the metal around the mounts and try and clean it up.
Old May 3, 2020 | 07:58 PM
JimmyCreedog's Avatar
Love the CRX, had a single cam Si when I was 20. Reading this thread makes me really want to go get a welder and fab some stuff up. What are you using?
Old May 4, 2020 | 01:39 AM
tigArex's Avatar
I'm using a miller dynasty 350 from work, wish i owned my own little shop though. Ive had this thing since high school. Happy i never sold it.
Old May 4, 2020 | 02:11 AM
tigArex's Avatar
bought a dual regulator to try and start making turbo manifolds.
Old May 6, 2020 | 08:49 AM
tigArex's Avatar
been working too many hours to work on the car but i just ordered some 5" pipe to finish the trailing arms.
Old May 6, 2020 | 01:42 PM
Caoboy's Avatar
-Intl Steve Krew
Loved
Why such a big pipe?
Old May 7, 2020 | 04:02 AM
tigArex's Avatar
bolts hits on 3"
Old May 7, 2020 | 06:33 AM
Wheel bearings will thank you for not running spacers. The shocks on the other hand. Going to double the lever arm on the suspension. Probably will need double the spring rate and valving.
Old May 7, 2020 | 02:37 PM
tigArex's Avatar
long one would have the axle about that far out
Old May 11, 2020 | 02:21 PM
tigArex's Avatar
Just picked my material. Bought some extra material just incase.
trying to find the strength to go to work at 3am to finish this up but working 65 hours is getting to me
Old May 11, 2020 | 02:31 PM
Caoboy's Avatar
-Intl Steve Krew
Loved
Know them feels.
you have an IG?
Old May 11, 2020 | 03:36 PM
tigArex's Avatar
Originally Posted by Caoboy
Know them feels.
you have an IG?
not one I use
Old May 12, 2020 | 12:37 PM
tigArex's Avatar
didn't make it in early but I got a little done during lunch.
Old May 13, 2020 | 02:15 PM
tigArex's Avatar
Should have gone with the 4.5" pipe but this will work I guess. Bought enough material to make about 7 sets.
found some 1/4 " stainless in the scrap pile.
need longer bolts
just placed on top not done
Old May 24, 2020 | 08:50 AM
tigArex's Avatar
still on jacked up but this is a rough look at it stretched
Old Jun 22, 2020 | 03:31 AM
tigArex's Avatar
finally got some time off so I came in early to fix some mistakes. Messed up the brake caliper location but everything fits when you have a welder!
will add more material and grind smooth
replacing the torx bolts with something longer
finishing the support
too short!
Old Jun 22, 2020 | 05:13 AM
Caoboy's Avatar
-Intl Steve Krew
Loved
It's only metal, make it move
Old Jun 22, 2020 | 06:29 AM
Chef Andre's Avatar
HT's TOP CHEF
Nice build so far!!! Will be following along.
Old Jun 22, 2020 | 04:21 PM
tigArex's Avatar
some progress during lunch
should have it cleaned up and evened out by tomorrow.
Old Jun 22, 2020 | 04:59 PM
Holy weld build up! Why not band saw out some 1/4" plate? Even a zip disc would work. Geebus! That was a lot of gas and a lot of heat!
