Transmissions noise
Old Apr 5, 2020 | 08:17 AM
ki11r0y1086's Avatar
Default Transmissions noise
I have a 95 JDM GSR trans with a factory LSD in a 91 CRX. I have new motor mounts, suspension, brakes, bushings, bearings, tie rod ends, and other goodies. When i release the clutch in any gear i hear a thunk, its more noticeable in 1st, 2nd, and reverse. With the car in neural while coasting I hit the brakes and don't hear a noise, when in gear I hit the brakes a slight thunk. My first thought was suspension or bushings but they are all new and installed correctly. I then checked for clearance around the motor (B20) and any where it might be hitting. I have yet to find anything. While the car is on jack stands I am having a friend put it in 1st/revers and pull the clutch out. I will be looking at the motor to see if it is hitting any where then do the same test on the ground. When the car is on jack stands I can rotate one wheel roughly 10 degrees before the other side starts to spin. I also hear a loud clack noise from the trans once the other side starts to rotate. This seems to me it is the diff. Before I take the trans out to rebuild it is their any other test I can do? or any other ideas? If it is the diff can I rebuild it? If I need to buy a new diff can I use an LS with an aftermarket LSD? I know the bolt pattern is different but if i replace the whole unit will it work in the trans? Thank you for your help and stay safe during this crazy time.
ThatNukkaTito
Transmission & Drivetrain
Aug 25, 2016 11:12 PM
MotorMouth93
Jun 14, 2016 01:58 PM
portenio78
Feb 26, 2012 12:25 PM
Jimmy
May 28, 2011 12:53 PM
garyc17
Jun 1, 2007 09:19 PM
