timing question
Old Nov 15, 2002 | 11:42 AM
civbeater90's Avatar
Default timing question
hey guys quick question.if i needed to retard my timing cuz of an aftermarket crank pulley do i do it at the cam gear or at the crank pulley itself?
Old Nov 15, 2002 | 12:14 PM
Desslok's Avatar
Default Re: timing question (civbeater90)
If you changed just your crank pulley, it shouldn't have affected your timing.
Old Nov 15, 2002 | 01:30 PM
Default Re: timing question (sp)
this is a fresh rebuild motor.it hasnt been started.the crank pulley was machined for a crank trigger.it seems like maye the timing marks on the pulley are off or maybe im assuming the wrong one is the timing one.it cranks and seems like it is too advanced to start.that is why im asking about setting the timing.
Old Nov 15, 2002 | 03:39 PM
Desslok's Avatar
On yours, the timing is set on the crank? Is there only one mark? Mine is set at the flywheel, and there is a BTDC mark, a 15 BTDC mark and a small mark on each side of that one. There is usually a service connector you need to jumper to set timing also.
Old Nov 15, 2002 | 04:07 PM
how do i do that?
Old Nov 15, 2002 | 04:36 PM
kinesistech's Avatar
To the left of the exhaust manifold where the tranny meets the engine, there should be a small rubber plug in the block. Remove it and shine the timing light in there. To retard it turn the distributor towards the front of the car.
Old Nov 15, 2002 | 05:36 PM
Desslok's Avatar
Default Re: timing question (kinesistech)
ANd the service connector is a Blue 2 pin plug taped up above passenger kick panel. I use a paper clip to jump the two wires. Make sure it is at proper idle when adjusting.
[Modified by sp, 2:37 AM 11/16/2002]
Old Nov 15, 2002 | 07:46 PM
ok guys so the service connector is only messed with once i get this running correct?
Old Nov 15, 2002 | 07:49 PM
redcxhatch's Avatar
Put your stock pulley back on! Your main bearings will thank me in 10k miles.
Old Nov 15, 2002 | 08:21 PM
Desslok's Avatar
Default Re: timing question (redcxhatch)
Only the rear bearings will thank you, there won't be enough left of the front ones to thank you.
Old Nov 15, 2002 | 09:02 PM
MrTodd's Avatar
Haha, no kidding. Don't mess with aftermarket/modified crank pulley's on a Honda motor!
Just put a stock one back on, and you won't have to worry about any timing issues.
Old Nov 16, 2002 | 12:39 PM
Default Re: timing question (MrTodd)
ok first off this is a stock crank pulley.it was machined for a trigger sensor.
Old Nov 16, 2002 | 12:46 PM
Desslok's Avatar
If you are having this much trouble, what I would do is get the #1 cylinder at TDC make sure the ignition rotor is on the #1 plug position and make sure your cam gear arrow is pointing up and the alignment marks are even with the top of the head. THat is a good place to start.
90si-rex
Sep 20, 2009 08:47 PM
VisualEcstasy
Apr 15, 2003 09:00 AM
89JDMcrx
Sep 25, 2002 05:22 PM
Nick248
Sep 9, 2002 09:59 PM
