95 civic buildup (low budget build)
Old Mar 27, 2020 | 07:37 PM
89brokendownEF's Avatar
Default 95 civic buildup (low budget build)
So
I bought this civic for the low, I since been fixing dents and rust. And I put on the muffler tip
I ordered all things for timing job seals belt pump etc, also ordered all new front suspension balljoints arms etc.
I want to drop the car a few inches but wanna keep the project low buck. Got less than 1k with all parts ordered. 167k miles on it
Old Mar 27, 2020 | 07:47 PM
Default Re: 95 civic buildup (low budget build)
What's cheapest I can drop but still maintain decent ride
Old Mar 28, 2020 | 12:15 AM
Quicksight87's Avatar
I’d say 200$!
Old Mar 28, 2020 | 04:27 AM
Originally Posted by Quicksight87
I’d say 200$!
What brand or what should I get
Old Mar 28, 2020 | 05:57 PM
egsleepercivic's Avatar
people seem to be happy with progress coilovers, and "decent" is subjective and doesn't really go well with cheapest
Old Mar 29, 2020 | 06:50 PM
Putting in work, fabbed all new metal lip around wheel well and cut out and replaced all rusty metal​​​​​​
Old Mar 29, 2020 | 06:51 PM
Old Mar 29, 2020 | 06:56 PM
U guys think these will be any good?
Old Mar 29, 2020 | 11:27 PM
man I’m not really sure. Maybe someone else will know 🤷🏽‍♂️
Old Mar 29, 2020 | 11:29 PM
Based on how much rust you had and the location; while it’s jacked up I would look at the floor board under the rear passenger seat. That metal too may need to be cut out and replaced. I have a little bit of rust there as well and mine has similar rust around the wheel wells. Check it out while you’re there. 👍🏽
Old Mar 30, 2020 | 03:51 AM
This is the quarter before i got to it, ill look underneath today. But from what i remember seeing the underside is pretty much rust free.
Old Mar 31, 2020 | 06:09 PM
Default Re: 95 civic buildup (low budget build) BUILD THREAD
So this is what I got done today on the project car, noticed the inner joint was binding.
what do u guys think I have a set of used axles off a 97 civic, should I use those or should I get one from advance auto. I dont really want to go into there again for a while after everything is replaced.
More to come tomorrow
Old Apr 1, 2020 | 06:46 AM
99stockcivic's Avatar
Axles are cheap today for a stock setup, buy new. $16 to $40 from Rock Auto. Don't waste time with some used axles at this price range.
Old Apr 1, 2020 | 05:49 PM
Picking up set for 63 shipped. This thing will handle/be amazing when I'm through
No pics but got otherside stripped out as well. Have to remove lower control arms tomorrow
Old Apr 7, 2020 | 06:10 PM
So got new cv axles, lower control arms, upper control armd, sway links and shocks installed both sides and timing job done My friend is pressing in new balljoints, bearings, and new dust shields into my spindles
vtechskipper
Engine Management and Tuning
Apr 19, 2013 02:27 PM
lildaine65
Sep 20, 2011 09:31 AM
Young Wise
18
Jul 17, 2002 11:58 AM
