Is it possible to change a FWD '95 Civic into a RWD?
I am going to get a FWD '95 Honda Civic and I just wanted to know if you could change it into a RWD. And if so, what would be needed to do, and is if inexpensive?
Re: Is it possible to change a FWD '95 Civic into a RWD? (Young Wise)
well I cant help you on the specifics but I would not expect that changing out the entire drivetrain would be the least bit inexpensive. I have a feeling if you want RWD that you should sell the civic and buy something that comes w/ it from the factory
Re: Is it possible to change a FWD '95 Civic into a RWD? (B_Cruz)
The Top Fuel del sol was converted to RWD, but that is a major racing company in Japan, not just some regular guy from Georgia.
here just buy this car...they did all the hardwork for you already, all you have to do is add your favorite motor, tranny and many more stuff and off you go!
https://honda-tech.com/zerothread?id=224137
New User
Re: Is it possible to change a FWD '95 Civic into a RWD? (pagong)
damn that **** is nuts. its very simple...all you need is a **** load of cash thats about it really
Re: Is it possible to change a FWD '95 Civic into a RWD? (Endless)
n8's car is going to be setup RR though. its not going to have a body either.
Re: Is it possible to change a FWD '95 Civic into a RWD? (DragonCTR69)
those aren't real time AWD.. even if it says it is... it is FWD mostly unless the wheels loose grip then the back tires come into play..
so basically you wouldn't move if you took out the front axles
Re: Is it possible to change a FWD '95 Civic into a RWD? (mafioso102)
I saw a pic of a AWD Civic coupe. It has a Mitso Evo7 I think. I can't remeber what series it is but it's a Mitso AWD turbo. I saw the pic @ Ultima Performance in NY.
