Troubleshooting: Tapped Compressor cover as vacuum source, but no readings. why?
Old Mar 27, 2020 | 08:44 AM
EGAJohn's Avatar
Default Troubleshooting: Tapped Compressor cover as vacuum source, but no readings. why?
So this is the second turbo now that I had this issue with. When I bought my first turbo it didn't come with the tapped vacuum source on the compressor housing. Therefore I drilled the flat spot right before the compressor outlet and tapped a 1/8" npt hose barb. Once I got everything hooked up my wastegate would not open. I checked the source from the turbo and boom no vacuum or boost. As a fix I just ran my vacuum line to the intake manifold and everything worked I just had an issue in cold weather with the wastegate not opening fast enough. About a year later I built my motor and bought another turbo and tapped it again the exact same way and again no readings! Im not sure if there's a trick to this but I've watched so many videos and I cant find the issue.
Old Mar 27, 2020 | 09:23 AM
Txdragon's Avatar
Default re: Troubleshooting: Tapped Compressor cover as vacuum source, but no readings. why?
May not have found the issue as to why but, you've certainly found a solution: use the intake manifold! Done and done.
Old Mar 27, 2020 | 02:58 PM
turboLScrx's Avatar
25 Year Member
Loved
Community Favorite
what he said...... never use the tap off the turbo......ALWAYS use a vacuum line from the intake manifold
Old Mar 27, 2020 | 04:29 PM
TheShodan's Avatar
Moderator
Exactamondo.. I'm just waiting for EGAJohn to show the standard Turbosmart image of the compressor housing being used as a vacuum source.
Old Mar 27, 2020 | 04:51 PM
EGAJohn's Avatar
Default Re: Troubleshooting: Tapped Compressor cover as vacuum source, but no readings. why?
That's what I've always done but every company I talk to says to always pull from the turbo. I guess I'll just stick to what I know works!
Old Mar 27, 2020 | 07:17 PM
Nathan937's Avatar
I know is not recommended by many on here, but you should still get a signal out of the compressor housing. Guys have had issues with it being a reliable source, but it’s odd the issue your having. Not getting any signal at all from that port just doesn’t make any sense.
I know I pull my source from my compressor housing. When I pulled it from my intake manifold after the TB, I was getting bad compressor surging at part throttle/heavy accel. I switched it back to the housing and I haven’t had any more issues.
Old Mar 28, 2020 | 04:08 AM
Txdragon's Avatar
To hopefully add a bit more insight on this issue.. Is there any way the turbo itself could have any bearing on whether or not the compressor housing tap would be effective or not? I myself have used the housings in the past with no difficulty noted. On the recent Garrett, it had no housing tap at all so I was forced to head to the IM. Now, I've had difficulty before with the IM source but now, I do not.
So.. Could turbo specs and performance play any part on the housing source?
Old Mar 28, 2020 | 04:55 AM
turboLScrx's Avatar
25 Year Member
Loved
Community Favorite
ths less efficient your intercooler is the more drastic the difference is. If your intercooler is not efficient enough for the boost you are going to run you will see resistance on the hot side of the intercooler which will show a higher boost pressure than what is actually hitting the intake which causes the wastegate to prematurely open. This will cause a pretty big performance loss, especially on cars running lower boost levels since the wastegate prematurely opening will cause the turbo to not spool up as fast. If you have a intercooler that has zero resistance you won’t really have a issue. Put if you want your wastegate to open at a consistent pressure.......ALWAYS use the the intake manifold as a reference point. There is a reason every performance shop uses the intake manifold as the reference point. If your only running 5-6 psi who cares , your not making much power anyway and probably won’t notice the difference
Old Mar 28, 2020 | 05:13 AM
Txdragon's Avatar
Oohh, good call! I didn't think about the IC. I hadn't had morning coffee yet either. Lol!
Old Mar 28, 2020 | 05:19 AM
turboLScrx's Avatar
25 Year Member
Loved
Community Favorite
some of us just naturally wake up bright
99ek4Dr
Mar 6, 2013 07:14 PM
97dc2
Jun 7, 2005 11:16 PM
pissedoffsol
Mar 26, 2004 07:04 PM
Ty.
Feb 3, 2004 04:15 AM
djnikko
Nov 28, 2003 02:11 PM
