Starts with start fluid but keeps running
Old Mar 25, 2020 | 04:14 AM
RicerBoi16's Avatar
Default Starts with start fluid but keeps running
So I install a fresh head in my z6 and install everything to plan but when I go to start it don’t start but only with starter fluid and it stays running with out starter fluid. but has a loud clicking sound almost like a bad case of lifter tick or something. Tried driving it off my driveway and it shut off
Old Mar 25, 2020 | 07:39 AM
NVturbo's Avatar
O.G. triple O.G.
Default Re: Starts with start fluid but keeps running
did you reconnect the ground wires at the thermostat housing ??
Old Mar 25, 2020 | 08:43 AM
RicerBoi16's Avatar
didn’t touch ground fuel pump primes as it should
Old Mar 25, 2020 | 02:31 PM
NVturbo's Avatar
O.G. triple O.G.
mechanical timing is off. Double check that if you haven't already
Old Mar 26, 2020 | 06:55 PM
RicerBoi16's Avatar
it was loose valve lash, tightened them up and runs quiet and smooth, still has fuel issues
Old Mar 29, 2020 | 07:53 AM
muellersfan's Avatar
Details?
Old Mar 29, 2020 | 08:18 AM
RicerBoi16's Avatar
Originally Posted by muellersfan
Details?
has a mega fuel leak at the top of the fuel rail, assuming o rings and also misses while idleing, the top of the injectors look wrapped probably from previous owner tightening fuel
rail hard as ****
Old Mar 29, 2020 | 08:35 AM
rail hard as ****
Fix fuel leak and then go from there. Also clean the IACV.
jarhead90crx
12
Sep 24, 2011 08:27 AM
NYCE
Feb 14, 2011 05:15 AM
uneek4dr
Oct 11, 2006 08:08 PM
battlecrxT
Apr 21, 2006 01:08 PM
92civeg
Sep 23, 2003 08:23 PM
