What thread chaser for head install?
Old Mar 19, 2020 | 02:49 PM
charlyhtx487's Avatar
Default What thread chaser for head install?
Well looks like my kids car needs the head replaced. I'm going to try to do it myself, researching parts to buy now. I see I need to get a thread chaser to clean the head bolt threads before installing the new head bolts, just wondering what size chaser do I buy. It's a 2000 civic dx. Thanks fellas
Old Mar 19, 2020 | 05:04 PM
muellersfan's Avatar
Default Re: What thread chaser for head install?
10 X 1.25 mm
AutoZone has a free rental
https://www.autozone.com/loan-a-tool...set/391372_0_0
Old Mar 20, 2020 | 06:57 AM
LiteraCola's Avatar
Corvette Forum Member
Originally Posted by muellersfan
10 X 1.25 mm
I would also suggest purchasing a thread pitch gauge. For the future, of course.
$12 on Amazon.
Old Mar 20, 2020 | 07:07 AM
$12 on Amazon.
Interested. Can you post link?
Old Mar 20, 2020 | 05:33 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
My die and tap set came with two of them, one SAE and one Metric. I find the thread pitch first then decipher the size after to see if I have the right die and the right tap.
Here is on that has both SAE and Metric in one set for 13 bucks CAD.
51/52Pcs Stainless Steel Screw Pitch Gauge 60 and 55 Degree Thread Plug Gage Measuring Tool Metric+ Imperial (52pc)(Metric+ Imperial(52pc)) 51/52Pcs Stainless Steel Screw Pitch Gauge 60 and 55 Degree Thread Plug Gage Measuring Tool Metric+ Imperial (52pc)(Metric+ Imperial(52pc))
Old Mar 20, 2020 | 07:22 PM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
Importantly, use a proper chaser and not a tap which removes material. Nice to know Autozone does the rental, however you may find that your rental chaser is not long enough for the length of the hole. In this case, adapt a standard bolt of adequate length to the problem by creating your own DIY chaser.
Old Mar 21, 2020 | 03:38 PM
LiteraCola's Avatar
Amazon Amazon
tada!
Old Mar 22, 2020 | 05:48 PM
egsleepercivic's Avatar
here is the arp thread cleaner\chaser
https://www.jegs.com/i/ARP/070/912-0002/10002/-1
Old Mar 23, 2020 | 04:29 AM
LiteraCola's Avatar
If you have access to a plug tap (bottom tap), that's essentially the same thing as a thread chaser.
Though, I have found that using taps from the kits does it make it very easy to get crooked... and then the threads are ruined. Most of the kits only supply "middle" taps.
Old Mar 28, 2020 | 12:05 PM
Carlos Moore's Avatar
I have one head bolt that gets rough after a few turns by hand. Somebody suggested I use this never used one before how does it work?
Old Mar 28, 2020 | 03:00 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Please see your thread, reply is there.
JGTW
Engine Machining & Assembly
Mar 26, 2019 03:46 PM
DelSol-B18
Sep 8, 2012 06:24 PM
blacc_ej1
Jun 1, 2011 01:34 PM
Don Johnson
Jan 20, 2006 07:35 AM
