Performance General Performance oriented Parts (Ex: Camshafts, Electronics, Air Intakes, Exhausts, complete engines)
Dropping weight? Lose up to 40 lbs. with Antigravity Batteries!
Old Mar 11, 2020 | 10:40 PM
Antigravity Batteries's Avatar
Icon2 Dropping weight? Lose up to 40 lbs. with Antigravity Batteries!
Hello all,
In case you are not familiar with lightweight Lithium-Ion batteries from Antigravity Batteries, here is some basic info...
Lithium-Ion (LiFePo4) batteries offer some significant benefits over the traditional Lead-Acid batteries. They generally pack a lot more Cranking Power, they last up to 3 times longer, and they weigh a lot less!
We all know how hard and expensive dropping extra weight can be once we've removed all the unnecessary stuff. Carbon-fiber parts can set you back hundreds, even thousands of dollars. Why not replace your heavy, old lead-acid battery with an Antigravity Battery and drop some significant weight? Our automotive batteries weigh only 8.5 to 18 lbs. depending on size and capacity. Your typical lead-acid battery weighs 30-50 lbs. For additional weight savings, even our motorcycle/powersport batteries can be used in a lot of Honda vehicles, due to the high cranking power. These weigh from 3 to 7.8 lbs. For example, one of our customers with a Prelude Si replaced his 39 lb. lead-acid battery with our ATX20-RS powersport battery that weighs only 3.8 lbs.! That's 35.2 lbs. less under the hood. This can serve as a great compensation for the extra weight you've added to your CRX or Civic by swapping the engine. And since there are no acids to spill, they are perfect for show cars with spotless engine bays.
Additionally, our batteries come with full BMS (Battery Management System) with cell-balancing, along with over-charge, over-discharge, and thermal protections, making them some of the safest, longest lasting batteries on the market. But that's not all... We're the first company to introduce the revolutionary Restart technology, aka Wireless Jump-starting, which means no more getting stranded due to a dead battery. When critically low on power, rather than over-discharging, our batteries will simply go into "sleep mode" and will save enough reserve energy for a few more starts. Then, you simply press the "Restart" button and start the car as if nothing happened. Two Restart key fobs come with each car battery, so you don't even have to open the hood. Jump-start your battery remotely! No more waiting for roadside assistance or asking strangers for a jump-start. Just press the button, start the car, and off you go. It's that simple.
No matter the year and model of your Honda, we've got you covered. Drag, autocross, road race, super high compression? No problem! We've got direct replacements as well as super small batteries for pretty much any automotive application. A lot of Honda racing teams have been successfully using our batteries for years. Spoon Civic, K-Tuned TypeR, and many others use Antigravity Batteries batteries for maximum weight savings.
Our car batteries come with a 5 year warranty, and motorcycle/powersport batteries with a 3 year warranty.
Here are just some examples:
https://antigravitybatteries.com/pro...ive/ag-51r-rs/
https://antigravitybatteries.com/products/starter-batteries/restart-oem/atx30-hd
https://antigravitybatteries.com/pro...-oem/atx20-hd/
https://antigravitybatteries.com/pro...-oem/atx20-rs/
We have frequent sales and giveaways, so follow us on social media for discount coupons and chances to win free stuff!
If you have any questions, please don't hesitate to contact us.
Old Mar 19, 2020 | 08:51 AM
Default Re: Dropping weight? Lose up to 40 lbs. with Antigravity Batteries!
Hi everyone,
Coupon codes are now active. The sale ends on 03/22.
Please contact us with any questions.
NewTeacher2017
Feb 4, 2020 10:30 AM
cess_pool
Jun 11, 2017 06:54 AM
s2kfromhell
Jul 15, 2010 08:24 PM
bamage
Aug 3, 2009 08:20 AM
