I have a 92 civic si with b series in it sheepy built top mount kit and I'm having trouble trying to find a filter that will fit the turbo to keep debris from sucking in but its a tight fit any recomendations?
would something like this help out? i'm guessing at what size you would need, the linked website has many sizes available (t-bolt clamps too). you could use any cone filter you like at the end, this gets you clear of the headlight housing area and back closer to the driver's side mount.
See I bought one of those actually the exact on an it was the right angle to grt the filter in between the core support and body mount but the filter wont fit in between those two
Ill take a better pick when I get home I have maybe like 4 to 4 and a half inchs in between engine mount and core support and like maybe 3 inchs from turbo to core support
