Cylinder head chatter and P0325
Old Mar 11, 2020 | 08:00 AM
Hondo91's Avatar
Default Cylinder head chatter and P0325
I recently swapped D16y8 bottom end and trans into my 99 Civic d16y7. The previous motor broke a rod. I had the head decked, leak tested, cleaned, and valve seals replaced and I recently put it back together when the car is cold it runs good but after 10 or 15 mins I hear chatter from the top end that's noticably different from when it first started and ideas on what to do now?
Old Mar 11, 2020 | 08:11 AM
muellersfan's Avatar
Default Re: Cylinder head chatter and P0325
You appear to be running a P2P ECU with a D16Y7 head atop a D16Y8 block. If correct, you need a P2E ECU.
sohc_freak
Sep 15, 2006 01:15 AM
A1
Northern California (Sales)
Jul 18, 2006 01:33 AM
A1
May 1, 2006 09:23 PM
Bense
Feb 13, 2006 06:10 PM
Lsos
Sep 12, 2003 04:48 AM
