Cannot go WOT from pedal
Old Mar 9, 2020 | 09:04 PM
Hasan Khurshid's Avatar
Default Cannot go WOT from pedal
Hi
If I manually go and open TB with my hand I can open it wide open but if I press the accelerator pedal to the floor, it doesn't open throttle complete in fact it's around 60% to 70%.
also i have checked there is no slack in the pedal.
What should I do?
Old Mar 9, 2020 | 10:12 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Cannot go WOT from pedal
Is your pedal arm bent ? What about something like a floor mat or carpet stuck under the gas pedal ? If you have no slack, I can't think of any other reason why you cannot get the throttle blade fully open.
Old Mar 10, 2020 | 05:52 AM
muellersfan's Avatar
Also inspect cable for a kink.
Old Mar 10, 2020 | 12:52 PM
chrysler kid's Avatar
Of the 7 civics I had, I had one civic LX that had a bent pedal arm assembly. Mine was so bent when I got the car id estimate it only went to 30% throttle
Check the pedal assembly out, its probably bent. I was never able to get mine to stay back where it needed to be so i got a replacement pedal set from the junk yard
Old Mar 11, 2020 | 11:37 AM
stin1's Avatar
Loved
Community Favorite
I thought all your threads were consolidated. Is there slack in the cable ? They can stretch . You can adjust them sometimes if so . Slack at the manifold/ throttle body.
Old Mar 11, 2020 | 04:52 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
They were, doesn't stop creating a new thread.
In this case, this issue isn't car specific so could prove helpful to others by being a separate thread by itself with the possible fixes.
Old Mar 11, 2020 | 06:32 PM
wunfstgsr's Avatar
Loved
Community Favorite
You probably have the wrong throttle cable and its too short.
93EG_Anton
Mar 2, 2020 05:55 AM
mkazm83
Jul 5, 2007 08:47 PM
Un0Turb0-WP
Welding / Fabrication
10
Dec 30, 2004 07:58 AM
AndrewCJ
Jun 5, 2003 08:08 AM
Ideal
Nov 1, 2002 07:17 PM
