Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Civic SI ticking noise
Old Mar 9, 2020 | 10:31 AM
Mikey D's Avatar
Default Civic SI ticking noise
I have a 2007 Civic SI with 145k miles. (K20Z3) I noticed this ticking noise after the first time i adjusted the valves on it. So of course I figured it was the valves, but now they've been adjusted like 4 times by me and taking to a shop to do the vavles and timing chain. The noise is still there! Im not sure if this is normal or natural. I never ever noticed it when I first got the car and I'm usually very sensitive to engine noises so I don't know I broke something somehow when first doing the valves or what! Only think I can think of is either the valves or I know I replaced the PCV valve around the same time could it be that? I know people say the K20s are loud and have loud injectors and I have used injector cleaners so maybe that made the injectors louder? I feel like I would've noticed this noise before or something, but its possible I suppose. So is this noise normal or natural? I feel uncomfortable with how loud it is, although I'm quite certain its nothing catastrophic. The car is stock other then a K&N Cold air intake FYI.
Old Mar 10, 2020 | 07:57 AM
4drEF's Avatar
Keyboard Humorist
Default Re: Civic SI ticking noise
That's does not sound like normal tick.
Is it louder/quieter when it's cold/warm?
Old Mar 10, 2020 | 08:32 AM
Mikey D's Avatar
I cant really hear the tick above 2k RPM so when I first start the car it sounds fine but once it’s below 2k RPM I can hear it and it’s the loudest and idle around 900 rpmish
Old May 21, 2020 | 07:30 PM
MechTech8's Avatar
My 09 Si sounded like this also. I changed the belt and I saw the belt as worn and I didn't hear that noise. And at times it may sounded like that whet I had the ac or heater on. But I don't hear it any more but at times when cold.
Old Sep 14, 2022 | 08:33 PM
Facu1995's Avatar
Hi man! Have you ever solved this ? What was it? Im having some similar sound.
Old Sep 15, 2022 | 11:35 PM
av911's Avatar
I'd agree with the above poster, it's the belt or at least in that area. Belt, belt tensioner, etc...
Mikey D
K Series
Mar 9, 2020 10:25 AM
projectac
Jul 29, 2005 07:24 AM
85civic
Aug 31, 2004 07:22 AM
JDM-EJ1
Jun 12, 2004 03:10 PM
carcala
May 29, 2002 10:54 PM
