E brake cable removal
Old Feb 24, 2020 | 03:03 PM
Delta Gill's Avatar
Default E brake cable removal
E brake cable is threaded through the control arm and there is a metal bracket that prevents the cable from being taken out. Anyone know how to remove the cable. I'm refurbishing the suspension.
Old Feb 25, 2020 | 04:52 AM
Freedo_Civegra's Avatar
Default Re: E brake cable removal
Disc or drum brakes?
1. Remove the small hairpin clip from the pin, then remove the pin from the end of the cable and the parking brake actuating bracket.
2. Remove the retaining clip from the cable and pull the cable through the hole.
Old Feb 25, 2020 | 05:52 AM
Delta Gill's Avatar
Disc. My main issue is how to get the retaining bracket off because that's what is keeping it from going through the hole.
Old Feb 25, 2020 | 07:14 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
There is the spring clip right at the bracket in your photo. I believe if you slide that off, you can then detach the bracket.
Also, what year, make, model and trim car?
Old Feb 26, 2020 | 06:21 AM
Delta Gill's Avatar
Also, what year, make, model and trim car?[/QUOTE]
'95 DelSol Vtec with the 1.6L B16A3
Old Feb 26, 2020 | 11:22 AM
Grab the spring clip with some channel locks and start wiggling it...
Old Feb 28, 2020 | 01:13 PM
Delta Gill's Avatar
Well the clip has been removed and the bracket still wont come off...
Old Mar 1, 2020 | 03:08 PM
Fiddn to get funky. Get you some penetrating oil and 2 pairs of channel locks. Spray it, let it set, spray it again, let it set, and get twisty with it...
Old Oct 8, 2020 | 09:20 AM
GoroLeto's Avatar
Is no. 1 a screw pin with a flat head screwdriver or pass through?
Old Oct 8, 2020 | 04:23 PM
It's a pin held in place by a hairpin clip.
peter_vang
Dec 14, 2010 05:28 PM
imadigitalgod
Jan 5, 2010 01:23 PM
ONEhaque
Nov 10, 2008 06:23 PM
MechEng
Dec 7, 2003 09:13 AM
