D16y7 to D15B Swap non vtec, need ecu advice
98 Civic, Manual Transmission, with a blown motor D16y7 (non vtec), so I ordered a JDM that was sold as a d16y7, but what came in was a d15b, with a AT. My son was mostly done with the swap when he noticed the engines were different.
The cam position sensor and knock sensor were swapped to the 15, and everything is running with the old d16 ecu, but it's running quite rich and sluggish, but not throwing any codes.
The ecu that was attached to the engine really has me scratching my head, it's a 37820-p44-g71,made in the UK, which the only thing I found is a rover 600?
Which ECU do I need to actually get this running? Or a guide to chipping the current ecu? (I'm a electronics tech, so soldering and programming eproms are no big deal)
Thanks.
Thanks.
Thanks.
Thanks.
.:FFS TechNet : CKF Bypass Trick :.
cityofcaterpillars
Engine Management and Tuning
Apr 13, 2016 07:06 PM
