Oil leak found between block & head gasket. where could it be from?
Old Feb 20, 2020 | 10:34 AM
Oskar Talkowski's Avatar
Default Oil leak found between block & head gasket. where could it be from?
Anyone know why or what could be causing this oil leak, engine is a b18c4
Old Feb 22, 2020 | 08:18 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: Oil leak found between block & head gasket. where could it be from?
Isn't your distributor on that side of the head. Usually the oil you see in that area is from the distributor o-ring leaking, or the cap for the other cam. I'm assuming the B18C4 is a DOHC so one would have the dizzy while the other would have a seal cap.
Old Feb 23, 2020 | 07:34 AM
muellersfan's Avatar
The B18C4 is also a VTEC engine, and VTEC solenoid oil leaks are as common as distributor oil leaks.
SathheshG
May 27, 2017 03:47 PM
yuen
Nov 12, 2006 06:43 AM
deepnite
Oct 9, 2002 01:46 PM
