No crank no start issue,
I have a 99 B20b swapped 2000 ek converted to obd1, not cranking not starting has power I hear the fuel pump and headlights are good. Multi metered everything, starter is good battery good and all grounds are connected cleanly. Clutch safety switch has been bypassed for a while now. Don’t believe it’s the main relay because I can hear it click on. Is there anything I’m missing? My mind is blown.
I redid the oil pump seals because it was leaking and redid the timing but the timing is on perfect. If anyone has any suggestions please let me know
Can you pop start it?
Not sure if your B20 has the crank sensor on the oil pump if so did you plug that back in? im still not sure if that would cause a no start..
Only other thing id suggest is double check the timing, are you 100% positive you put the Timing belt on and mech. timing is set ?
So you replaced the oil pump seal and timing belt and now it wont start?
So what would be the problem if the car did crank, we just got to the point where we can actually start it and it's turning over and everything but it's not actually starting. We're even getting pops right out the exhaust. I'm putting a b20z2 into a 2000 civic, not sure if that would change anything. We tried to adjust the distributor, we re did the timing, starter works, battery is working, the only thing I can really think of is maybe like something with the idle screw or whatever. And what happens if the Crankshaft sensor isn't plugged in?
F22VTECyo!
Jul 20, 2016 07:55 PM
gsrekrevs210k
16
Jan 9, 2011 02:49 PM
