DIY Master Cylinder Brace (Photos enclosed) built and installed in 1 day :)
Old Nov 15, 2002 | 09:12 AM
Philly_NBP_R's Avatar
Default DIY Master Cylinder Brace (Photos enclosed) built and installed in 1 day :)
Update - I created a better version out of T304 Stainless, here's the dimensions I used:
As promised - pics of the new and improved SS brace:
Note:
This is posted only for suggestion, feel free to modify it as needed for your application. I suggest creating the brace first, then drilling shock tower area, then locate the exact place for the holes on brace. Unfortunately, I had to drop the shock to get the two bolts in, as this area is very tight. Let me know if you have a better method. I will post pics of the new bracket soon. For those of you that don't have access to this type of steel, I'm sure you can find something similar at Home Depot
Okay, so after reading a few posts detailing various types of master cylinder braces, I decided to have a crack at it. Definately a great cheap mod, and you CAN feel the difference at the brake pedal. Unfortunately I also recently installed Stainless lines as well, so I can't give a 100% accurate review, but the pedal is definately stiffer. Here's some pics for your enjoyment
Cylinder Brace before installation:
Brace installed side view:
Brace Installed top view:
It wasn't that hard of an install - only had to take the suspension apart
If you look close you can see the stainless line and where the holes for the cylinder brace were drilled (just above the shock mounting brace thingy)
Type aRRRRRR suspension - oWned
Lucky for me we have a decent machine shop here at work, where they cut me a nice piece of rolled steel for the brace (that sucker is STRONG). A quick trip to home depot yielded some nice stainless nuts, bolts, and washers. A little drilling, test fitting, and sweat, and the thing was in! Home Depot mods friggin OWN!!!
enjoy.
Nick
[Modified by Philly_NBP_R, 10:50 AM 11/27/2002]
[Modified by Philly_NBP_R, 10:54 AM 11/27/2002]
Old Nov 15, 2002 | 09:16 AM
arren123's Avatar
Default Re: DIY Master Cylinder Brace (Philly_NBP_R)
Ok.. you have to help me out here, because I'm totally clueless. How exactly does this brace improve brake pedal feel?
Old Nov 15, 2002 | 09:19 AM
Default Re: DIY Master Cylinder Brace (arren123)
well, you should do a search, but I'll enlighten you anyway.
The master cylinder assembly moves slightly when you stomp on the pedal. This is caused by flex at the firewall. If you don't believe me, have a buddy stomp on your brake pedal, and you can see it move. The brace prevents this flexing, yielding a stiffer pedal. Stiffer brake pedal inspires more confidence, and gives better "feel." This mod is mostly for the track, but you can feel it in daily driving.
Old Nov 15, 2002 | 09:20 AM
TypeR76's Avatar
nice job.
Old Nov 15, 2002 | 09:26 AM
RTW DC2R's Avatar
Default Re: DIY Master Cylinder Brace (TypeR76)
smoothness
Old Nov 15, 2002 | 09:28 AM
arren123's Avatar
Ahh. Makes sense. Thanks! How about popping out a few more braces for us folks at honda-tech (since you did a very nice job and all)
Old Nov 15, 2002 | 09:30 AM
Big Teggie's Avatar
Looks good. I made my own brace from some big L brackets that you use when building decks. They are pretty dam strong and get the job done nicely. I noticed a big difference when stopping from 80+mph.
DIY OWNz JOO!!!
I'd love to, but unfortunately I don't have ready access to the machine shop or the steel
I'd be happy to provide measurements if you want to have a crack at it...
Old Nov 15, 2002 | 09:31 AM
Default Re: DIY Master Cylinder Brace (Big Teggie)
DIY OWNz JOO!!!
yes, it sure does!!!
Old Nov 15, 2002 | 09:32 AM
GM2000ITR's Avatar
New User
Please do!!
Old Nov 15, 2002 | 09:41 AM
Default Re: DIY Master Cylinder Brace (GM2000ITR)
okay, I'll take some tonight, and post asap
Old Nov 15, 2002 | 09:58 AM
Rob Dizzle's Avatar
nice setup
the depot kinda sucks because they dont have metric
but otherwise, verycool
Old Nov 15, 2002 | 10:05 AM
00R101's Avatar
Default Re: DIY Master Cylinder Brace (Bob-DC2)
OK - now you've got the master cylinder bolted to 2 pieces of sheetmetal (the firewall and the wheelwell) Both those pieces of metal move independently of eachother as the chassis flexes. Is there any concern that the master cylinder casting will see increased metal fatigue because it now acts as a chassis stiffener? Just curious.
Also everyone should recognize that this mod is not legal for stock class auto-x.
Regards,
Alan
Old Nov 15, 2002 | 10:11 AM
Default Re: DIY Master Cylinder Brace (00R101)
actually the master cylinder is NOT bolted to anything. The brace simply prevents it from moving. I was concerned about metal fatigue, and that's why I was careful to make sure that the brace was not exerting any pressure on the cylinder. This brace would only come into action if the firewall flexes and the cylinder attempts to move. I also made sure that the bolt that touches the cylinder itself was completely flat, to spread out the load and prevent damage to the cylinder. I didn't realize I would be kicked out of stock class, but I'm not too concerned about that anyway.
Old Nov 15, 2002 | 11:27 AM
Asahi's Avatar
Stock is for sissy
SandMracing.com is where it is at y0!
Old Nov 15, 2002 | 12:30 PM
Default Re: DIY Master Cylinder Brace (Asahi)
Stock is for sissy
true dat!
Old Nov 15, 2002 | 05:48 PM
sil's Avatar
sil
nice setup
the ones in canada do..
Old Nov 15, 2002 | 06:04 PM
frogsr's Avatar
great job. looks like a very solid piece.
Old Nov 15, 2002 | 07:10 PM
Art Vandeleigh's Avatar
[Modified by Philly_NBP_R, 1:13 PM 11/15/2002]
now that is what a garage is supposed to look like
sweet!!! can you get some more of the machined metal piece for the people who dont have access to a machine shop?
Old Nov 15, 2002 | 08:19 PM
BimmerSteven's Avatar
Lightness comes at a price.
Old Nov 16, 2002 | 03:33 AM
AzN_Flava's Avatar
Default Re: DIY Master Cylinder Brace (BimmerSteven)
hehe someone wanna start making those pieces at a decent price?
Old Nov 16, 2002 | 06:33 AM
Default Re: DIY Master Cylinder Brace (AzN_Flava)
will be posting measurements shortly...
unfortunately I can't get anymore of the metal, but it shouldn't be too hard for you to find something of suitable size.
Old Nov 26, 2002 | 07:59 AM
ttt - updated thread...more pics to come
Old Nov 26, 2002 | 08:42 AM
Ricky Rojales's Avatar
Nice.
Old Nov 26, 2002 | 01:39 PM
scooter's Avatar
Default Re: DIY Master Cylinder Brace (P)
LHT Performance sells MC Braces for the ITR for $60 shipped. They are very easy to install, no suspension removal required, it just bolts up to pre-existing holes in the fender well.
Contact me for info at Scutr22@aol.com
scott
98 ITR turbo
