03 accord k24a4 5spd help
Been dealing with a problem all winter. Codes p0107 p0122 tps and map sensor codes. Car will shut off and stall out until warmed up (3 to 4 times) Replaced tps, calibrated it to specs. Replaced map sensor. Checked all wiring and grounds. Bought whole new throttle body and gaskets and still same issue. Only happens when cold outside. If it’s 40Degrees or above outside car runs fine and codes go away. Can someone steer me in the right direction? Any help is appreciated thanks!
99turboaccord
Mar 1, 2019 08:46 AM
kennyosho
10
Apr 16, 2010 08:14 AM
1sickaccord
Jul 23, 2002 12:29 AM
