98 CX plug into 00 si ecu?
Old Nov 15, 2002 | 09:03 AM
itrSteez's Avatar
Default 98 CX plug into 00 si ecu?
hey will the stock ecu plugs on a 98 cx plug into the ecu of a 99-00 si
Old Nov 15, 2002 | 09:10 AM
Kataku2K3's Avatar
Default Re: 98 CX plug into 00 si ecu? (prawjEKt Cx)
Sorry, but NO.. the 96-98 Civic's run OBD2a using plugs A,C,D in the ECU... 99-00 Civic's run OBD2b and use the plugs A,B,C.... You could get away with this if you had a harness convertor but it won't work straight over.. Laterz
Old Nov 15, 2002 | 09:31 AM
Nameless RB26's Avatar
Default Re: 98 CX plug into 00 si ecu? (JDMspecEG6)
That's right. It'll plug in, but won't work.
Old Nov 15, 2002 | 11:33 PM
itrSteez's Avatar
Default Re: 98 CX plug into 00 si ecu? (Nameless)
**** so if i get a full 2000 b16 swap what should i do, get a obd2 ecu outta a 96-98 gsr....... but what a bout all the extra sensors a gsr has?:
Old Nov 16, 2002 | 01:26 AM
Kp_VtekNiks's Avatar
jumper harness and go obd1
Old Nov 16, 2002 | 05:10 AM
VTECVillain's Avatar
Actually the 96-98 GSR P72 would work on that motor and you wouldn't throw any codes. The only extra sensor the P72 has is the Secondary intake air bypass and it doesn't have a check code. The best thing I would recommend is buying an OBDII to OBDI harness and run an OBDI ECU - chipped P28, P72, etc.
My friend is running a Skunk 2 programmed OBDI P72 in his car - 96 CX with 00 B16A2, no check engine lights and it runs really strong.
Old Nov 16, 2002 | 06:44 AM
H22EK's Avatar
Default Re: 98 CX plug into 00 si ecu? (VTECVillain)
i've got the jumper harness and a p28 if you need!!!!
Old Nov 16, 2002 | 10:21 AM
Trey's Avatar
25 Year Member
Default Re: 98 CX plug into 00 si ecu? (H22EK)
Don't use the GSR ecu with a B16a swap. It will bog below 4400 rpms and suck.
GSR has a dual stage manifold.
All other B swaps have a single stage manifold.
Just do like the rest have suggested and either get an OBDIIa to OBDIIb jumper harness or even better an OBDIIa to OBDI jumper harness and a chipped OBDI ecu.
9civic808
10
Nov 10, 2013 08:12 PM
goofyej6
Dec 15, 2007 05:04 AM
CiviCVuE
Mar 9, 2007 02:47 PM
got rice
Mar 31, 2002 10:55 AM
got rice
Mar 30, 2002 01:43 PM
