Cracked a Cylinder - Piston Salvagable?
Old Feb 11, 2020 | 04:32 PM
ccrunner16's Avatar
Default Cracked a Cylinder - Piston Salvagable?
Hey everyone!
I recently cracked a cylinder on my B series build and have no idea what constitutes a piston as reusable or not. I doubt this one is. Take a look at the attached images! No damage to the top, only the bottom skirt.
Old Feb 11, 2020 | 10:05 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Cracked a Cylinder - Piston Salvagable?
Yeah, you have turned that one into an ashtray.
Old Feb 12, 2020 | 09:32 AM
1HGEJ2's Avatar
u can coat it. in germany we have some shops about coating.
Beispiele
here a sample. i would find a shop
Old Feb 12, 2020 | 12:32 PM
Aradin's Avatar
Premium Member
If the scratches aren't too deep you can polish it and reuse it. I'm not saying you should but it's been done. Probably better off just buying another piston.
Old Feb 12, 2020 | 08:55 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Isn't one of the bottom edges of the skirt bent (4th thru 6th pics) ? The scratches ARE deep... check the first three pics from the top and look just under the oil/scraper ring.
Old Feb 13, 2020 | 03:19 AM
NVturbo's Avatar
O.G. triple O.G.
what's likely the culprit here...a poor install?
Old Feb 13, 2020 | 12:57 PM
Aradin's Avatar
Premium Member
He said he cracked a cylinder so I'm guessing he split a stock sleeve and this damage is from metal debris getting sandwiched between the skirt and bore. Engine probably wasn't shut down right away. Given the pistons lack any kind of dome I'm going to assume this is a turbo build. Stock sleeves will eventually give up even if a "safe" higher power level is maintained for awhile on a forced induction setup.
1320london
Engine Machining & Assembly
Sep 17, 2016 12:00 PM
Stoich EG2
Jul 18, 2007 04:29 AM
turbotime
Nov 2, 2006 11:06 AM
doublejz
Oct 4, 2005 01:27 PM
