OBD scanner low voltage.
Old Feb 10, 2020 | 01:58 PM
seven6zero's Avatar
Default OBD scanner low voltage.
Recently picked up a EJ, took it to get smogged, smog guy hooked his scanner up but kept getting "low voltage" error.
I took the car home and looked under steering column, to find out somebody tried to install aftermarket alarm system, what would be the best place for me to start for correcting the smog issue?
Thanks for any help.
Old Feb 10, 2020 | 02:28 PM
Swift's Avatar
Default Re: OBD scanner low voltage.
Remove the alarm and fixed any hacked wires.
Old Feb 10, 2020 | 02:36 PM
muellersfan's Avatar
What year Civic?
Old Feb 10, 2020 | 03:58 PM
seven6zero's Avatar
Originally Posted by muellersfan
What year Civic?
its a 96..
update: i took the car after driving for 45 mins and now its able to be read, but now i have a oxygen sensor monitor and Catalyst Monitor failure..
thanks for the responses
Old Feb 11, 2020 | 09:12 AM
416Gang's Avatar
Maybe check your Alternator then battery then power wires and grounds. If you drove around and it was able to read, the battery had to be low on power or the alternator is getting tired of recharging the battery.
Old Feb 11, 2020 | 11:31 AM
seven6zero's Avatar
I just recently bought a brand new alternator and battery, maybe a month ago, but ill go over the wiring.. thank you
Old Feb 11, 2020 | 11:45 AM
Does the scanner work when plugged into other cars? If so, measure the voltage on the power pin of the OBD2 connector. Also measure continuity to body ground on the ground pin. I think there are only three pins in the connector.
Niceguy123
Jul 23, 2015 03:45 PM
caliprelude3087
Jan 22, 2006 12:08 PM
red_ek_hatch
Mar 21, 2005 05:57 PM
bbcnet
Jul 9, 2004 02:32 AM
