K24 swapping my ep3
Hello everyone, I was just wondering if anyone has put a k24a2 into their ep3 and i was wondering what recommendations you had to do the swap. If i can im probably only going to get the engine and ecu if possible. Any suggestions would be appreciated. Thanks
It has been done thousands of times. You will need a CRV right side engine bracket and a water neck for the front of the engine... move your I/M over along with your upper idler assembly. You will have to alter your heater hoses and your radiator hoses. The K24A2 ECU will not work in your car... you will need to get your EP3 ECU modified for tuning... like K-Pro so that you can upload a K24 map.
delante(ej1)
Jul 17, 2011 07:44 PM
