Is there a place to buy valve covers setup for breathers?
Old Feb 6, 2020 | 12:09 PM
Stopsign32v's Avatar
Loved
Default Is there a place to buy valve covers setup for breathers?
I'm no welder and I'm still driving my car so is there a place that sells LS valve covers that are already welded with breather bungs and painted or what?
Old Feb 6, 2020 | 12:20 PM
Txdragon's Avatar
Default Re: Is there a place to buy valve covers setup for breathers?
https://jhpusa.com/collections/valve-covers
Old Feb 6, 2020 | 12:43 PM
2kdrift's Avatar
You can find them on ebay although don't see any at the moment... Better yet read the catch can faq no need to modify vc. I've tried both unless your making massive power no need for vc
Old Feb 6, 2020 | 12:52 PM
Loved
Yea I think I might do that and keep the battery up front. Not bad advice
You are talking about this right? https://honda-tech.com/forums/forced...vents-3335314/
Edit: That nice of a write up with links and all but no part number for the check valve you use?? Tha fu
Old Feb 6, 2020 | 01:05 PM
2kdrift's Avatar
Yup... Sourced a drain back catch can on ebay, oem fittings on ebay and got the lines and aftermarket fitings from b&r.
When I had vc setup I would constantly have to drain. The can pain in the *** for a street car
Old Feb 6, 2020 | 01:18 PM
Loved
Looking at that setup it still has the valve cover to intake line but with a "turbo check valve". Would that still allow oil into the intake? I'd think so.
Old Feb 6, 2020 | 01:23 PM
2kdrift's Avatar
No it shouldn't that portion is optional but better for a street car. I haven't had any signs of burning oil.
Here's the can I went with i like it alot
Old Feb 6, 2020 | 01:27 PM
Loved
Can you post a picture of your setup? It looks pretty small. You aren't draining back into the motor are you? I plan to empty mine when I do oil changes. I was looking at this one. Would probably take out the drain thing on the bottom, thread in a brass fitting and run a line to the bottom of the car, put a valve, and just open it when I'm under there changing the oil. https://www.ebay.com/itm/AN10-Polished-Aluminum-Oil-Catch-Can-Reservoir-Tank-W-Breather-Filter-Baffled/274163222429?_trkparms=aid%3D111001%26algo%3DREC.S EED%26ao%3D1%26asc%3D20160908105057%26meid%3Dbf131 41f21224323a2341866601b33ee%26pid%3D100675%26rk%3D 1%26rkt%3D15%26mehot%3Dnone%26sd%3D274163222429%26 itm%3D274163222429%26pmt%3D1%26noa%3D1%26pg%3D2380 057&_trksid=p2380057.c100675.m4236&_trkparms=pagec i%3A03c9ee23-492e-11ea-8828-74dbd18013a3%7Cparentrq%3A1c916a121700aa13f5ab647c ffea2758%7Ciid%3A1
Old Feb 6, 2020 | 01:48 PM
2kdrift's Avatar
Actually your can looks smaller, depending on your boost it may need more frequent oil drains.
I use a drain back system no maintenence required
Old Feb 6, 2020 | 02:04 PM
Loved
I don't like the idea of condensation and crap back into the oiling system. That's another reason I liked the idea of the bigger box so it won't fill up as fast. BUT I really don't like the idea of putting the battery in the trunk.
Old Feb 6, 2020 | 02:21 PM
2kdrift's Avatar
There's no issue with drain backs the way it was explained to me is any water will evaporate upon startup also my can is always empty so I don't think there is condensation in the first place I'll get a pic later
Old Feb 6, 2020 | 07:50 PM
wunfstgsr's Avatar
Loved
Community Favorite
This is the valve I ordered works perfect.
https://www.ebay.com/itm/ATE-Power-B...item3f52f9cdd7
No I actually try explaining this on that thread.
This is the kit I use along with the check valve I shared.
https://www.projectimport.com/store/...-lok-fittings/
Old Feb 6, 2020 | 08:18 PM
2kdrift's Avatar
My can is about 7" tall and measures 3" across size is mostly irrelevant for me and it vents well and drains back couldn't fit much larger in my bay anyway.
I have never seen any signs of oil or condensation
Old Feb 7, 2020 | 09:33 AM
TheShodan's Avatar
Moderator
You don't need the -10AN welded bungs at all. see the stickies.
soiii
Mar 9, 2011 10:15 AM
Rikaro
Jun 26, 2008 03:01 PM
ekVtecPower
16
Jul 5, 2006 12:04 AM
rsrintegra2000
Dec 9, 2003 08:04 PM
