Putting a 93-95 D15B7 in a 92 civic Dx.
Hey guys, I just have a simple question. The map sensor on my 92 eg is firewall mounted and the motor I'm putting in has the map sensor on the throttle body. Can I just use the harness from my 92 civic on the newer motor and just plug the terminal to the throttle body mounted map sensor and it work just fine? I know the only difference is that the 92 has the map sensor wire on the chassis harness and the newer ones have it on the engine harness. So could I just plug the terminal from the 92 harness to the map sensor instead of using the harness that has the terminal located on the engine harness from the newer motor and get the same result?
williejohnson
Dec 9, 2006 05:26 PM
